おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Grove Base Shield for Photon is an expansion board which incorporated the standard Grove interfaces to let you build more powerful and intelligent applications with richer and cost-effective Grove functional modules. It gets three digital ports, two analog ports, two I2C ports and one UART port. It’s a plug-and-play shield designed to accelerate prototyping dramatically.
Attention
This shield can not work with Particle Mesh, only compatible with Particle Photon
  • Compatible with Photon
  • Standard Grove interfaces to connect to a large family of Grove sensors and actuators
  • I2C, UART ports integrated
  • Grove Ports: 3 digital ports, 2 analog ports, 2 I2C ports and 1 UART port.
  • Dimensions: 53 x 53 mm
  • Weight: 18g
Application ideas
  • Compact IoT applications such as smart router.
ドキュメント
認証
HSCODE8543909000
USHSCODE8543903500
UPC841454118459
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions65mm x78mm x11.8mm
WeightG.W 19g
BatteryExclude
部品リスト
Particle Photon Base Shield1
SKU 103020031
Specially designed for Photon Plug and play Up to 8 Grove ports for various types of interface Compact design Provides 4 fit-holes
USD$6.90
廃番
product.detail.alsoAdd.title
