おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High Efficiency Design — Typical efficiency up to 88% (24V model) with no-load power consumption <0.75W.
  • Wide Range Input — Selectable input voltage (90–132VAC / 180–264VAC) via switch; withstands 300VAC surge for up to 5 seconds.
  • Comprehensive Protections — Short Circuit, Overload (110–140% Hiccup mode, auto-recovery), Over Voltage (28.8–33.6V), and Over Temperature Protection.
  • Smart Cooling System — Built-in intelligent temperature-controlled fan; activates at ≥50°C and stops at ≤40°C to extend lifespan.
  • Extreme Environment Ready — Operates reliably from -25°C to +70°C (full load) and up to 5000m altitude.
  • Low Noise Output — Ripple & Noise ≤ 150mVp-p (measured at 20MHz bandwidth).
  • Global Safety Certified — Complies with IEC/UL 62368-1, CCC (GB4943.1), BSMI, and EAC TP TC 004 standards.
  • Superior Reliability — MTBF ≥ 2,099,900 hours (calculated per Telcordia SR-332).
  • Anti-Vibration Design — Withstands 5G vibration (10–500Hz) for 60 minutes in each axis (X, Y, Z).
仕様
ItemSpecification
Model NumberPower Adapter Kit for reBot Arm B601-DM
Dimensions (L×W×H)263.5 × 121 × 38.8mm(L×W×H)
Net WeightApprox. 0.76 kg
Input Voltage Range90–132VAC / 180–264VAC (Selectable via Switch)
Frequency Range47 – 63 Hz
AC Input Current3.4A Max. @ 230VAC (Typical)
Inrush Current60A @ 230VAC (Cold Start, Typical)
Efficiency (Typ.)88%
DC Output VoltageDC 24V
Rated Output Current14.6A
Rated Output Power350.4W
Ripple & Noise≤ 150mVp-p
ProtectionsOLP / OVP / OTP / SCP
Operating Temp.-25°C ~ +70°C
Operating Humidity20% ~ 90% RH (Non-condensing)
Storage Temperature-40°C ~ +85°C
Storage Humidity10% ~ 95% RH
Safety CertificatesIEC/UL 62368-1, CCC (GB4943.1), BSMI CNS15598-1, EAC TP TC 004, EN 61558-1, EN 61558-2-16, BIS IS13252(Part1), KC 62368-1 (for 12V/24V Models)
認証
HSCODE8504401400
USHSCODE8504409510
UPC
EUHSCODE8504409590
COOTaiwan, China
部品リスト
Power Adapter Kit for reBot Arm B601-DMx1
CN Plug/Cordx1
US Plug/Cordx1
EU Plug/Cordx1
XT30U Female to XT60 Male Cablex1
SKU 100029903
This is a 350W high-efficiency industrial-grade AC-DC switching power supply delivering a stable DC 24V, 14.6A output. It features a selectable input voltage switch for 115VAC or 230VAC (compatible with a wide range of 90–264VAC) and achieves a typical efficiency of up to 88%.
Designed for robust performance, it includes comprehensive protection circuits against Short Circuit, Overload, Over Voltage, and Over Temperature. The integrated cooling fan features intelligent on/off control based on thermal load.
Fully compliant with international safety standards including IEC/UL 62368-1 and CCC (GB4943.1), this unit is ideal for industrial automation, control systems, and electronic instrumentation. It boasts exceptional reliability with an MTBF ≥ 2,099,900 hours and supports universal US/CN/EU power cords.
USD$59.00
product.detail.alsoAdd.title
