製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Build your own Arduino shield using the compact and flexible Proto Shield kit. Solder together a limitless range of circuits and reuse it in all your Arduino projects. A standard 0.1" prototyping grid accepts commonly used through-hole parts and chips. You could also find a range of basic components are included to help you get started with your custom shield.
  • Standard Arduino compatible
  • Large 0.1"*0.1" pitch prototyping area
  • A variety of through-hole sizes to fit most parts
  • Arduino UART and I2C port pin breakout for easy external communications
  • Dual ISP breakouts for easy programming and stacking
  • 3.3 volt, 5 volt, and ground power rails are easily available anywhere on the board
  • Breadboard style prototyping area
  • USB type B breakout
  • Basic components included (buttons, switches, LEDs, resistors, USB jack)
Packing List
  • 1x Arduino compatible Proto Board
  • 1x B type USB connector
  • 1x 40-pin 2.54mm male long header
  • 1x 40-pin 2.54mm female header
  • 2x 40-pin 2.54mm male header
  • 1x 40-pin 2.54mm spacer
  • 3x 8-pin 2.54mm female header
  • 1x 6-pin 2.54mm female header
  • 1x ISP female pin header
  • 1x ISP male pin header
  • 1x 10k Ohm rotary potentiometer
  • 4x 1k Ohm through-hole resistor
  • 2x 10k Ohm through-hole resistor
  • 2x 3mm Red through-hole LED
  • 2x 3mm Green through-hole LED
  • 1x 3mm dual color through-hole LED
  • 4x Mini push button switch
  • 2x DPDT switch
ドキュメント
認証
HSCODE8517709000
USHSCODE8517790000
UPC841454104803
EUHSCODE8517180000
COOCHINA
技術詳細
Dimensions110mm x80mm x21mm
WeightG.W 42g
BatteryExclude
部品リスト
Arduino compatible Proto Board1
B type USB connector1
40-pin 2.54mm male long header1
40-pin 2.54mm female header1
40-pin 2.54mm male header2
40-pin 2.54mm spacer1
8-pin 2.54mm female header3
6-pin 2.54mm female header1
ISP female pin header1
ISP male pin header1
10k Ohm rotary potentiometer1
1k Ohm through-hole resistor4
10k Ohm through-hole resistor2
3mm Red through-hole LED2
3mm Green through-hole LED2
3mm dual color through-hole LED1
Mini push button switch4
DPDT switch2
Shop Wifi Bee v2.0 at Seeed Studio, offering wide selection of electronic modules for makers to DIY projects. Quality Guarantees. Lifetime Tech Support. Full Tutorials and Projects.
SKU 103060000
JPY¥1567.00
廃番
