High-quality low loss CFD400 cable suitable for outdoor installation and weather extreme conditions. Length 3 meters with connectors N-Female to N-Male.
Fully compatible with technologies, products and services by
| Frequency Range | 0-6000MHz |
| Length | 3 meter ±50mm |
| Impedance | 50Ω |
| VSWR | Typical 1.1 @ 900MHz ≤1.5 max @ 6GHz |
| Insertion Loss | Typical 0.9db @ 900MHz ≤2.5db max @ 6GHz |
| Capacitance | 76pF/m |
| Velocity of Propagation | 85% |
| Connectors | Type N Male/Jack Type N Female/Plug |
| Insulation Resistance | >1000MΩ |
| Bend Radius | Min 25.4mm |
| Voltage Breakdown | 2.5KV |
| External Cable Diameter | 10.3mm |
| Connectors | Type N Female Type RP-SMA Male |
| Mating Cycles | >500 |
| Jacket Material | PE |
| Conductor Material | Copper |
| Binder Material | Aluminum/PE Tape |
| Braid Material | Tinned copper wire |
| Operation Temperature | -30℃ to +65℃ |
| Environmental | RoHS |
| HSCODE | 8544200000 |
| USHSCODE | 8544200000 |
| UPC | |
| EUHSCODE | 8517180050 |
| COO | CHINA |
