For some applications like in an urban environment or where large stretches of land have to be monitored the normal range of LoRa might not be enough. So If you need to increase the range for your LoRa devices, then this outdoor LoRa Fiberglass antenna will be the ideal addition to your LoRa system. It’s a robust solution to provide extra power and range for outdoor LoRa Base stations. The antenna has an average gain of 5.8 dBi, a length of 80cm, and a frequency range from 902-930MHz, and it comes with hardware for pole and wall mounting.
The Antenna has an N-J Double tooth connector, and it comes with an N-Female to RP-SMA plug cable so it can be easily connected to the SenseCAP Gateways.
The antenna can be used in any environment where long-range LoRa connections are required.
Frequency | 902-930MHz |
Impedance | 50Ω |
VSWR | ≤2.5 |
Gain | 5.8±1dBi |
Max Efficiency | >78% |
Radiation Pattern | Omni-directional |
Connector | N-Type Male |
Material | Fiberglass |
Length | 800±10mm |
Operation Temperature | -30℃~65℃ |
| Frequency Range | 0-6000MHz |
| Impedance | 50Ω |
| VSWR | <2.0 |
| Insertion loss | <0.5dB @900 MHz |
| Insulation resistance | >15 MΩ |
| Voltage breakdown | >500V |
| External cable diameter | 5mm |
| Connector | Type N Female Type RP-SMA Male |
| Conductor material | Copper |
| Binder material | Aluminum/PE Tape |
| Braid material | Tinned copper wire |
| Operation temperature | -40°C to + 65°C |
Antenna | 1* |
CFD200 cable 1mt | 1* |
Mounting Bracket | 1* |
N Type to RP-SMA cable (compatible with Solar Node) | 1* |
Fibreglass LoRa antenna with a gain of 5.8 dBi, frequency range 902-930MHz, and 800mm length, comes with a CFD200 cable with 1m length and a mounting bracket, compatible with SenseCAP M1 Indoor Gateway.
