製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
It is a good plastic box for Raspberry Pi, which can protect it with one of these snazzy plastic enclosures?. These cases protect the Raspberry Pi from things like rogue wires that might short it out while still allowing full access to the board! Simply snap the RPi into the bottom half of the enclosure, then snap the two sides together.
The enclosure provides slots to access the peripheral header, USB ports, Ethernet, SD card, HMDI, composite video, audio, CSI and JTAG connectors as well as feet and vents to ensure the board gets proper cooling and plus-shaped wall mounting slots. All of the status LEDs on the Pi are visible through the case thanks to light pipes embedded in the design. This is a really slick case and once you've gotten your hands on a Raspberry Pi, you'll want to snag one of these to put it in!
  • made with ABS plastic
  • Compatible with Raspberry Pi B+/2/3B/3B+
  • equipped with the breather hole
  • smooth surface
  • Easy to fixed
  • Unibody, esy to install
  • Colors: Black
  • Case size: 90x60x25mm
  • rubber plastic non-slip mats x 4
  • set screws x 4
認証
HSCODE8543909000
USHSCODE8543903500
UPC841454100171
EUHSCODE8543709099
COOCHINA
技術詳細
Dimensions0mm x0mm x0mm
WeightG.W 35g
BatteryExclude
部品リスト
Pi Case1
Raspberry Pi B+/2/3B/3B+ Enclosure - Black
SKU 114990123
made with ABS plastic Compatible with Raspberry PiB+/2. equipped with the breather hole smooth surface Easy to fixed
JPY¥784.00
