製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • High-performance 64-bit Quad-core Cortex A72  processor
  • More memory options (1GB/2GB/4GB/8GB), suitable for large data compilation
  • Dual display(HDMI) support at resolutions up to 4K
  • Faster eMMC flash with up to 100 MB/s transfer rate, 4x faster than CM3+
  • Added wireless module option with on-board PCB antenna and external antenna for industrial applications
  • Designed with B to B connectors for enhanced stability
  • Add on-board Gigabit Ethernet design, support IEEE1588, suitable for network application development
  • Add PCIe interface expansion, can flexibly add related modules
The Raspberry Pi Compute Module 4 (CM4) leverages the computing power of the popular Raspberry Pi 4 Model B, with dramatic performance changes compared to its predecessor: faster CPU cores, better multimedia, more interface capabilities. And for the first time, this release offers multiple choices of RAM density and wireless connectivity options.
In terms of external dimensions, this version adopts a completely new mechanical standard. The overall footprint of the module on its carrier board is reduced, resulting in a smaller and more compact form factor suitable for integration into products.
For storage, the Raspberry Pi Compute Module 4 (CM4) has an optional 8GB, 16GB, or 32GB onboard eMMC, which is different from the Raspberry Pi 4's Micro SD card slot.
This version of the Raspberry Pi Compute Module 4 includes a high-performance 64-bit quad-core processor, 8GB LPDDR4 RAM, 32GB eMMC, dual-display support at resolutions up to 4K, hardware video decode at up to 4Kp60, Gigabit Ethernet, USB 2.0, dual camera interfaces, PCIe Gen 2 x1 interface, and dual-band 2.4/5.0GHz wireless LAN and Bluetooth 5.0.
The dual-band 2.4/5.0GHz wireless LAN and Bluetooth 5.0 have modular compliance certification. This allows the board to be designed into end products with significantly reduced compliance testing, improving both cost and time to market. Either the onboard antenna or an external antenna kit can be used.
Seeed Studio also offers Raspberry Pi edge devices for edge computing, specifically tailored for Raspberry Pi CM4 customizable devices such as HMI and edge IoT controllers.
Specifications
SpecificationDetails
ProcessorBroadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
Memory8GB LPDDR4
Storage32GB eMMC
ConnectivityOptional wireless LAN, 2.4GHz and 5.0GHz IEEE 802.11b/g/n/ac wireless, Bluetooth 5.0, BLE with onboard and external antenna options
 Onboard Gigabit Ethernet PHY supporting IEEE1588
 1 × USB 2.0 interface
 28 GPIO signals
 SD card interface for SD card or external eMMC
VideoDual HDMI interface (up to 4Kp60 supported)
 2-lane MIPI DSI display interface
 2-lane MIPI CSI camera interface
 4-lane MIPI DSI display interface
 4-lane MIPI CSI camera interface
MultimediaH.265 (4Kp60 decode); H.264 (1080p60 decode, 1080p30 encode); OpenGL ES 3.0 graphics
Input power5V DC
Operating temperature0 to +80°C
Dimensions55 mm × 40 mm
Production lifetimeRaspberry Pi Compute Module 4 will remain in production until at least January 2034
ComplianceFor a full list of local and regional product approvals, please visit:
www.raspberrypi.org/documentation/hardware/raspberrypi/conformity.md
Hardware Overview
Model selection reference form
Part number nomenclature
Model
Wireless
RAM
eMMC storage
CM4
1 = Yes
0 = No
01 = 1GB
02 = 2GB
04 = 4GB
08 = 8GB
000 = None(Lite)
008 = 8GB
016 = 16GB
032 = 32GB
Product List
Wireless
RAM
Storage
Part Number
Price
No
1GB
Lite
CM4001000
102991380
$25.00
Yes
2GB
Lite
CM4102000
102991376
$35.00
Yes
2GB
8GB
CM4102008
102991377
$40.00
Yes
2GB
32GB
CM4102032
102991378
$50.00
Yes
4GB
16GB
CM4104016
102991433
$60.00
Yes
4GB
32GB
CM4104032
102991379
$65.00
No
8GB
Lite
CM4008000
102991434
$70.00
Yes
8GB
32GB
CM4108032
102991441
$90.00
Dimensions
Note
  • 4 x M2.5 holes in corners
  • All dimensions are in mm
1 x Raspberry Pi Compute Module 4 - 8GB RAM, 32GB eMMC, 2.4/5.0GHz Wi-Fi & Bluetooth 5.0
認証
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8473302000
COOUNITED KINGDOM
Raspberry Pi Compute Module 4 - 8GB RAM, 32GB eMMC, 2.4/5.0GHz Wi-Fi & Bluetooth 5.0 (CM4108032)
SKU 102991441
Recommended Upgrade
RK3576 Module 8GB RAM/64GB
8GB module matched with 8GB+64GB. Better for production carriers.
View RK Alternative →
Wireless
RAM
Storage
JPY¥33950.00
お問い合わせ
最小発注数量:250個
