製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
Buy Raspberry Pi Compute Module 5 (102111072/102111085/102111086/102111076/102111038) with 5% OFF NOW!
Same 5% OFF for CM5 MINIMA (114993698) —— Combination Purchase Save up to 5% Discount!
Raspberry Pi Compute Module 5 is a powerful system on module that delivers the performance of Raspberry Pi 5 in a compact form factor, making it ideal for embedded applications.
Similar the Compute Module 4 (CM4), the CM5 offers a range of options for eMMC storage(from 0GB, 16GB, 32GB, and now 64GB) and SDRAM (2GB, 4GB, 8GB, and now 16GB), as well as both wireless and non-wireless versions.
  • New processor: Upgraded from CM4 CPU model BCCM2711, quad-core Arm Cortex-A72, 1.5GHz to CM5 CPU model BCCM2712, quad-core Arm Cortex-A76, 2.4GHz.
  • New manufacturing process: Enhanced from CM4's 28nm to CM5's 16nm
  • Higher memory speed: Improved from CM4 LPDDR4-3200 to CM5 LPDDR4-4267
  • More memory options: Includes versions with 16GB SDRAM and 64GB eMMC flash memory
  • More powerful video output: CM5 supports dual 4K60P output and HDR
  • Stronger power supply: CM5's power interface has been upgraded from 5V3A to 5V5A, supporting the PD protocol
  • Extensive I/O interfaces: Including PCIe 2.0, USB 3.0, MIPI DSI/CSI-2, and up to 30 GPIOs supporting various protocols (UART, I2C, SPI, etc.).
  • GPU upgraded from CM4's 600MHz VideoCore VI to CM5's 800MHz VideoCore VII
  • CM5 supports 4Kp60 HEVC decoder and OpenGL ES 3.1, Vulkan 1.2.
仕様
Processor
Broadcom BCM2712 quad-core Arm Cortex-A76 (Armv8) SoC @ 2.4GHz
Memory
4GB LPDDR4
Storage
16GB eMMC
Wireless
● 2.4 GHz / 5.0 GHz IEEE 802.11 b/g/n/ac wireless
● Bluetooth 5.0, BLE
● On-board electronic switch to select between PCB trace or
external antenna
Ethernet
Onboard Gigabit Ethernet PHY supporting IEEE1588
USB
1 × USB 2.0 port (high speed)
2 × USB 3.0 ports, supporting simultaneous 5Gbps operation
PCIe
1 × PCIe x1 root complex, Gen 2 (5Gbps)
GPIO
Up to 30 × GPIO supporting either 1.8V or 3.3V signalling
and peripheral options:
● Up to 5 × UART
● Up to 5 × I2C
● Up to 5 × SPI
● 1 × SDIO interface
● 1 × DPI (parallel RGB display)
● 1 × I2S
● Up to 4 × PWM channels
● Up to 3 × GPCLK outputs
Video
2 × HDMI 2.0 ports
(supports up to 4Kp60 on both ports simultaneously)
2 × 4-lane MIPI ports
supporting both DSI (display port) and CSI-2 (camera port)
Multimedia
4Kp60 HEVC decoder
OpenGL ES 3.1 graphics, Vulkan 1.2
1 × SDIO 2.0 (CM5 Lite)
Input power
Single +5V PSU input supports USB PD for up to 5A @ 5V
Operating temperature
20°C to +85°C
MTBF Ground Benign
143 000 hours (168 000 hours CM5 Lite)
Dimensions
55 mm × 40 mm x 4.7 mm
Production lifetime
Raspberry Pi Compute Module 5 will remain in production
until at least January 2036
Compliance
For a full list of local and regional product approvals, please
visit pip.raspberrypi.com
Model selection reference form
Model
Wireless
RAM
eMMC storage
CM5
1 = Yes
0 = No
01 = 1GB
02 = 2GB
04 = 4GB
08 = 8GB
16 = 16GB
000 = None(Lite)
008 = 8GB
016 = 16GB
032 = 32GB
064 = 64GB
CM5 Product List
Part Number
Wireless
RAM
eMMC
Price
CM5002000
No
2GB
0GB (Lite)
$45
102111058
CM5002016
16GB
$50
102111059
CM5002032
32GB
$55
102111060
CM5002064
64GB
$60
102111061
CM5004000
4GB
0GB (Lite)
$55
102111062
CM5004016
16GB
$60
102111063
CM5004032
32GB
$65
102111064
CM5004064
64GB
$70
102111065
CM5008000
8GB
0GB (Lite)
$75
102111066
CM5008016
16GB
$80
102111067
CM5008032
32GB
$85
102111068
CM5008064
64GB
$90
102111069
CM5016000
16GB
0GB (Lite)
$115
102111070
CM5016016
16GB
$120
102111071
CM5016032
32GB
$125
102111072
CM5016064
64GB
$130
102111073
CM5102000
Yes
2GB
0GB (Lite)
$50
102111074
CM5102016
16GB
$55
102111075
CM5102032
32GB
$60
102111076
CM5102064
64GB
$65
102111077
CM5104000
4GB
0GB (Lite)
$60
102111078
CM5104016
16GB
$65
102111038
CM5104032
32GB
$70
101110141
CM5104064
64GB
$75
102111079
CM5108000
8GB
0GB (Lite)
$80
102111080
CM5108016
16GB
$85
102111081
CM5108032
32GB
$90
101110142
CM5108064
64GB
$95
102111082
CM5116000
16GB
0GB (Lite)
$120
102111083
CM5116016
16GB
$125
102111084
CM5116032
32GB
$130
102111085
CM5116064
64GB
$135
102111086
Raspberry Pi Compute Module 5 Development Kit
We also sell the official compete development kit for the Raspberry Pi Compute Module 5,
providing all products required to allow an engineer to start a design “out of the box”.
For more details, please click here: Raspberry Pi Compute Module 5 Development Kit
ハードウェア概要
Dimensions
Note:
All dimensions in mm
All dimensions are approximate and for reference purposes only
The dimensions shown should not be used for producing production data
The dimensions are subject to part and manufacturing tolerances
Dimensions may be subject to change
認証
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8473308000
COOUNITED KINGDOM
部品リスト
Raspberry Pi Compute Module 5 - 4GB RAM, 16GB eMMC, 2.4/5.0GHz Wi-Fi & Bluetooth 5.0
x1
Raspberry Pi Compute Module 5 - 4GB RAM, 16GB eMMC, 2.4/5.0GHz Wi-Fi & Bluetooth 5.0 (CM5104016)
SKU 102111038
This version of the Raspberry Pi Compute Module 5 includes a quad-core Arm Cortex-A76 processor, 4GB LPDDR4 RAM, 16GB eMMC, dual 4Kp60 HDMI output, hardware video decode at up to 4Kp60, Gigabit Ethernet, USB 3.0, dual camera interfaces, and PCIe Gen 2 x1 interface.
Wireless
RAM
Storage
JPY¥20576.00
お問い合わせ
最小発注数量:25個
