製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Supports 802.3at PoE standard with a high output power of 5V DC/4A
  • Built-in controllable brushless fan delivering 2.2 CFM for better heat dissipation
  • Fully isolated switched-mode power supply for better power efficiency
  • Compatible with Raspberry Pi 4B/3B+
The Raspberry Pi PoE+ HAT is an add-on board for Raspberry Pi computers with PoE pins, including Raspberry Pi 3B+ and Raspberry Pi 4. It is used to power Raspberry Pi via an Ethernet cable, provided that power-sourcing equipment is installed on the Ethernet network. It supports 802.3at PoE standard with high output power of 5V DC/4A and the built-in controllable brushless fan can deliver 2.2 CFM to cool the Raspberry Pi processor. It also features a fully isolated switched-mode power supply for better power efficiency.
Specifications
SpecificationDetails
StandardIEEE 802.3at-2003 PoE
Input voltage37–57 V DC, Class 4 device
Output power5V DC/ 4A
Cooling25 mm × 25 mm brushless fan delivering 2.2 CFM for processor cooling
FeaturesFully isolated switched-mode power supply
Fan control
Operating temperature0 °C to +50 °C
Production lifetimeThe Raspberry Pi PoE+ HAT will remain in production until at least January 2027
ComplianceFor a full list of local and regional product approvals, please visit
www.raspberrypi.org/compliance
Comparison Between PoE HAT and PoE+ HAT
PoE HATPoE+ HAT
Standards supported802.3af802.3af, 802.3at
Output voltage5V5V
Maximum output current2.5A4A
Maximum power12.5W20A
FanYesYes
Current senseNoYes
Transformer designWire-woundPlanar
PCB4 layers, 2oz copper4 layers, 2oz copper
Compatible withRaspberry Pi 3B+, 4BRaspberry Pi 3B+, 4B
1 x Raspberry Pi PoE+ HAT for Raspberry Pi 4B/3B+
ドキュメント
認証
HSCODE8543909000
USHSCODE8543903500
UPC
EUHSCODE8473308000
COOCHINA
SKU 106990388
JPY¥3166.00
