Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Explore the full reSpeaker lineup. Compare specs, find your ideal fit, and catch the latest updates & community news. Check the reSpeaker Series Landing Page
Note:
  • The reSpeaker 2-Mics Pi HAT has been upgraded to version 2.0. The codec chip has been replaced from WM8960 to TLV320AIC3104, enabling support for Raspberry Pi 5 and expanding the sampling rate range from 8 kHz to 96 kHz.
  • While the Pi HAT is a classic for DIY, the XVF3800 USB takes your project to the next level. No more kernel compiling or I2S troubleshooting. Plug it into your Pi 4, Pi 5, or PC, and it works instantly with professional hardware-grade noise cancellation.
  • Voice User Interface for Raspberry Pi Series: Placed by 4 analogue microphones, which come with the Voice Interaction algorithms of VAD(Voice Activity Detection), DOA(Direction of Arrival), KWS(Key Word Spotting)
  • TLV320AIC3104 Audio Codec: Low power, high-quality stereo Codec designed for portable digital audio applications
  • Controllable Peripherals: Provide 3 programable APA102 RGB LEDs and 1 User Button for attached Speech Recognition usage
  • Easy Assembly: Simply pop up on the Raspberry Pi to use
The reSpeaker 2-Mics Pi HAT is the voice user interface for Raspberry Pi Series, which has been equipped 2 analogue microphones and TLV320AIC3104 Audio Codec for high-definition voice capture. Attach with NLU software algorithms and noise reduction algorithms, it has the abilities of Voice Activity Detection, Direction of Arrival and Key Word Spotting, widely used in Voice Interaction applications.
How does reSpeaker work?
There are analogue microphones mounted on each corner of the square reSpeaker, to receive audio data around then transmit them to the codec. The codec integrates synchronized ADCs with mic boost amplifier, to deliver valid channel data to the Raspberry Pi/ Pi Zero, where it transits them over I2S ports by standard I2S or PCM format, along with a single port by TDM format.
The NLU algorithms will be applied to the Raspberry Pi once the audio data has arrived. The main functions include Voice Activity Detection(VAD), Direction of Arrival(DOA), and Key Word Spotting(WKS), suitable for various Voice Interaction applications such as voice-based remote control cars, voice user interface, keywords wake up and so on.
Since the audio data transmitted may contain the noise as well, the reSpeaker comes with the functions of Auto Echo Cancellation (AEC), Beamforming, Webrtc Noise Suppression (NS), and Automatic Gain Control (AGC) to reduce noise and perform better audio data to the Raspberry Pi.
Details
MIC
2 analog microphones
LED
3 APA102 RGB LEDs
Raspberry Pi 40-Pin Headers
Support Raspberry Pi5, Raspberry Pi Zero, Raspberry Pi 1B+/2B/3B/3B+/4B
TLV320AIC3104 codec
Low power, high quality stereo Codec designed for portable digital audio applications
Software Algorithm
VAD(Voice Activity Detection), DOA(Direction of Arrival) and KWS(Keyword Search)
User button
1 programmable button
Voice Capture Distance
3 meters radius voice capture
Battery
Exclude
Dimensions
65mm x 30mm x 15mm
Weight
G.W 33g
Application
  • Voice Interaction Learning
  • Secondary software Development
  • Voice-based remote control cars
Get started with Google Assistant
How to use button to trigger Google Assistant
Certification
HSCODE8518900090
USHSCODE8518108040
UPC841454120018
EUHSCODE8517180000
COOCHINA
Technical Details
技術情報
寸法65mm x30mm x15mm
重さG.W 33g
バッテリ含まれない
パッケージ内容
ReSpeaker 2-Mic Pi HAT1
SKU 107100001
このボードは低電力消費ステレオコーデックであるWM8960をベースにしています。2つのマイクロホンはボードの両側にあり、音声を収録します。
Mic Array Numbers
Voice Processor
XIAO ESP32-S3
Case
JPY¥2042.00
