Specification | Details |
Dimentions | 77mm (Diameter) |
Weight (N.W.) | 43.6g |
Weight (G.W.) | 104.2g |
① XMOS XVF-3000: It integrates advanced DSP algorithms that include Acoustic Echo Cancellation (AEC), beamforming, dereverberation, noise suppression and gain control.
② Digital Microphone: The MP34DT01-M is an ultra-compact, lowpower, omnidirectional, digital MEMS microphone built with a capacitive sensing element and an IC interface.
③ RGB LED: Three-color RGB LED.
④ USB Port: Provide the power and control the mic array.
⑤ 3.5mm Headphone jack: Output audio, We can plug active speakers or Headphones into this port.
⑥ TLV320AIC3104: The TLV320AIC3104 is a low-power stereo audio
codec with stereo headphone amplifier, as well as
multiple inputs and outputs that are programmable in
single-ended or fully differential configurations.
When it comes to development we believe you should have as many options as possible. The reSpeaker XMOS XVF3000 is able to work with most modern Linux, macOS, and Windows systems
reSpeaker USB Mic Array | x1 |
USB Type A to Micro USB cable | x1 |
Instruction Card | x1 |
ReSpeaker USBマイクアレイとはプラグアンドプレイでき、買ったらすぐにそのまま使うことができる音声ピックアップデバイスです。
