製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Equipped with emergency stop switch
仕様
Electrical Interface Definition
Pin
Terminal Marking
Terminal Function
Terminal Specification
1
GND
CAN interface ground
Cage-clamp terminal, wiring hole diameter Φ1.9mm
2
L
CANL
3
H
CANH
4
R-
Braking resistor connection
5
R+
6
24V power supply interface
XT30
7
Robot arm wiring terminal
XT30(2+2)
認証
HSCODE8537109090
USHSCODE8517620090
UPC
EUHSCODE8471707000
COOCHINA
Circuit Protection and Emergency Stop Switch Module for reBot Arm B601-DM
SKU 100050746
This product is specifically designed to handle the regenerative braking kinetic energy of the reBot Arm B601-DM joint module when operating under high rotational speed and heavy load conditions. This ensures that the power supply voltage does not rise excessively due to the regenerative energy feedback, thus preventing the occurrence of an error message indicating excessive bus voltage and resulting in machine shutdown.
JPY¥9481.00
