おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High-Performance Dual-Chip Architecture
Powered by the EFR32ZG23 + ESP32D0WDR2 dual-chip design, it supports the Z-Wave S2 security protocol, delivering strong anti-interference performance and ultra-fast local response.
  • Flexible Connectivity, Built to Last
Supports Ethernet, Wi-Fi, and USB connections for maximum flexibility. The aluminum alloy enclosure, tested with 24-hour salt spray resistance, ensures excellent heat dissipation and durability—even in humid or corrosive environments like basements.
  • Extended Range, Reliable Signal
With Z-Wave Long Range (ZWLR) support, it enables stable point-to-point long-distance communication. The 360° adjustable antenna ensures consistent performance even in complex environments.
  • Local Web Console for Easy Management
Features a dedicated LAN-based web interface to monitor device status, configure settings, and update firmware anytime. All data is stored locally, ensuring complete privacy and security.
  • Open Ecosystem, Seamless Integration
Fully compatible with major open-source platforms like Home Assistant, openHAB, and Z-Wave JS, allowing you to build a customizable and reliable smart home hub with ease.
仕様
ProductSONOFF Z-Wave 800 PoE Dongle Max
ModelDongle-MZG23
ConnectionEthernet/Wi-Fi/USB (*Supports PoE)
Antenna Gain3dBi
Number of Antennas2
SocEFR32ZG23+ESP32D0WD
Additional CapabilitiesWeb Console / Webhooks / AP Hotspot / Wireguard
Supported PlatformsHome Assistant / OpenHAB / Z-Wave JS
Cable IncludedUSB Type-C cable (1m)
Input5V=1A for Type C or 48V=-0.25A for PoE port
Wireless connectionsZ-Wave, Wi-Fi IEEE 802.11b/g/n 2.4GHz
Working temperature-10°C~60°
Casing materialsAluminum, PC+ABS
Network interface typeRJ45
ColorDim gray
ハードウェア概要
用途
  • Designed to connect Z-Wave devices to open-source platforms such as Home Assistant and openHAB
  • Ideal for flexible deployment with Ethernet (PoE), Wi-Fi, or USB connections, allowing optimal placement for Z-Wave coverage (living rooms, bedrooms, basements, warehouses, etc.)
  • Supports Z-Wave Long Range (ZWLR) for stable long-distance point-to-point communication with distant devices (garages, outdoor areas, weak-signal zones)
  • Enables fully local, cloud-free control with Z-Wave S2 security for privacy-focused smart home setups
  • Suitable for users who need a standalone network coordinator with local Web Console, MQTT, Webhooks, and VPN capabilities
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
SONOFF Z-Wave 800 Dongle Maxx1
Scew accessory packagex2
USB Type-C cable (1m)x1
Bracketx1
Double-sided tapex2
Quick guidex1
SKU 100084916
SONOFF Z-Wave 800 Dongle Max is a Z-Wave controller developed based on the ESP32D0+ EFR32ZG23, model Dongle-MZG23. It is designed to connect Z-Wave Devices to open-source platforms like Home Assistant and openHAB. It supports PoE power supply and offers multiple connectivity options, making it adaptable to various usage scenarios.
USD$44.90
product.detail.alsoAdd.title
