Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Motor-controlled Gripper Controlled by Damiao DM-4310 with abundant development resources for rapid prototyping and deployment
  • 3D-printed Kit All parts 3D printed, making it more accessible and easier to assemble. Provides 3D printing guide. 3D parts also aviailable for purchase.
  • Flexible Integration Can be attached to any CAN-based robot arm as end-effector for various gripping tasks
  • Swappable claw Users can swap out claws of different shapes without dissaembling the entire gripper
Product
DM-Gripper
Gripper Mechanism
Crank Slider
Gripper type
Parallel Gripper
Motor Model
Damiao DM4310
Rated Voltage
24 V
Rated Current
2.5 A
Peak Current
7.5 A
Rated Torque
3 NM
Peak Torque
7 NM
Rated Speed
120 rpm
Encoder Resolution
14 bits
Communication Protocol
CAN @ 1Mbps
Hardware Overview
Certification
HSCODE8501310000
USHSCODE8501106080
UPC
EUHSCODE8501109390
COOCHINA
F3-8M Miniature Thrust Bearing (ID-3mm × OD-8mm × Thickness-3.5mm)
x4
Stainless Steel Linear Rail MGN9, 200 mm
x1
Linear Rail Carriage MGN9C (Standard)
x2
DM4310-2EC Motor
x1
Phillips Pan Head Screw PM3×8
x8
Hex Socket Cap Screw M3×20
x4
Hex Socket Cap Screw M3×25
x6
Hex Socket Cap Screw M3×50
x8
Hex Socket Cap Screw M3×16
x12
304 Nylon Locking Hex Self-Locking Nut M3 (Thickness-3.9mm × Width-5.5mm)
x18
Spring Washer – M3
x4
Flat Washer – M3×7mm (OD) × 0.5mm (Thickness)
x8
DM-Gripper: Damiao DM4310 Parallel Gripper Kit (without 3D printed parts)
SKU 100094243
For 3D printed parts, you can either buy 100007512 DM-Gripper 3D printed parts or find 3D printed parts files below in Documents section DM-Gripper is an open-soure Damiao motor 3D printed parallel gripper kit. It is based on widely popular Damiao DM-4310-2EC motor (also seen on OpenArm) using crank slider mechanism, and comes with abundant development resources that enables developers for rapid prototyping and deployment. The gripper is easy to assemble and disassemble. Users can easily attach the gripper to any robot arm for various gripping tasks.
JPY¥22001.00
Discontinued
