製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Highly Integrated Multi-mode Satellite Positioning: Multi-mode satellite positioning & navigation and support more than 6 satellites at the same time
  • High precision Positioning: Positioning error within 10 meters,and the position still quickly and accurately under the condition of bad signal
  • The Integrated Design of RF Baseband: Adopt the integrated design of RF baseband, which integrates DC/DC, LDO, LNA, RF front-end, baseband processing, 32-bit RISC based chip, RAM, FLASH storage, RTC, and power management functions
  • Low Power Consumption: Low power consumption at only 31uA
  • High Compatibility: Compatible hard/soft interface for other modules
仕様
Confused about your GPS not working well in urban or outsides under only one or a few satellite module? Then you should not miss our new SeeedGrove-GPS (Air530Z). It’s a high-performance, highly integrated multi-mode satellite positioning and navigation module to use with Arduino. It supports GPS / Beidou / Glonass / Galileo / QZSS / SBAS, which makes it suitable for GNSS positioning applications such as car navigation, smart wear, and drone. Meanwhile, this module is capable of receiving more than 6 satellites at the same time and is able to work excellently even if there's a very bad signal.
SeeedGrove – GPS Module vs SeeedGrove – GPS (Air530Z)
SpecsSeeedGrove – GPS ModuleSeeedGrove – GPS (Air530Z)
Size40mm x 20mm x 13mm40mm x 20mm x 13mm
Update Rate1Hz, max 10Hz–
Baud Rate9,600 – 115,2009600 –256000
Navigation Sensitivity-160dBm-
Power Requirements3.3/5V3.3/5V
Number of Channels22 tracking, 66 channels–
Time to first startCold start: 13s
Warm start: 1-2s
Hot start: <1s
Cold start: <32 seconds
Hot Start: <1 seconds
AntennasAntenna includedAntenna included
Accuracy2.5m GPS Horizontal Position Accuracy2.5m Horizontal positioning accuracy
Parameters
values
Supply voltage
3.3V/5V
Working current
up to 50mA
Interface
UART
Time of hot start
<1s
Time of cold boot
<32s
Working Temperature
-30C-85°C
Storage Temperature
-55°C-100°C
Time of Positioning
Pure hardware cold start
<32s
Pure hardware hot start
<1S
Pure hardware recapture
<1S
Software-assisted A-GNSS
<5S
Sensitivity
Cold start
-148dBm
Hot Start
-156dBm
Recapture
-160dBm
Track
-162dBm
Accuracy
2m
Speed accuracy
0.1m/s
Time transfer accuracy
30ns
Consumption
Capture current [email protected]
33.3mA
Tracking current [email protected]
29.2mA
Ultra-low-power [email protected]
31uA
Note
The test above is taken under bi-modules of GPS&Beidou.
用途
  • GPS tracker
  • GPS navigation
  • Distance measurement
  • Car navigation
  • Drone
認証
HSCODE8526919090
USHSCODE8526910040
UPC
EUHSCODE9013101000
COOCHINA
部品リスト
GPS (Air 530Z) board
x1
SeeedGrove cable
x1
Cautions
  • The input power supply voltage of SeeedGrove power supply interface, should not exceed 5.6V, otherwise it may damage the device.
  • The voltage of the selected button battery should not exceed 3V, or it will probably damage the device.
Grove - GPS (Air530)
SKU 109020022
Grove-GPS (Air530) is a high-performance, highly integrated multi-mode satellite positioning and navigation module, supporting plenty of location systems, such as GPS/Beidou/Galileo and etc.
JPY¥1742.00
