おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
SenseCAP Wireless Light Intensity Sensor measures the intensity of light in lux from 0 - 188000 lux, which is designed for outdoor use.
This battery-powered device incorporates a built-in LoRa transmitter based on SX1276 for long-range transmission, a digital light sensor, and a custom battery. It is specifically designed and optimized for use cases powering end devices by batteries for years. To minimize the power consumption, the device wakes up, transmits the collected light data to the gateway, and then goes back to sleep.
Under the best of circumstances, the battery is expected to last for 8 years, depending on the data transmission intervals. Please kindly note that the default interval is once per hour. If you'd like to change the data upload interval, please refer to this document.
To fit in adverse conditions, it is designed with industry standards and equipped with an IP66 waterproof enclosure, supporting an extended operating temperature range, making it suitable for industrial applications in both indoor and outdoor severe environments.
SenseCAP Sensor Node adopts a modular design, integrating the data logger with the sensor probe, which is replaceable by other SenseCAP sensor probes.
About SenseCAP
Among the first launch of Seeed industrial IoT (IIoT) product series, SenseCAP is focusing on wireless environmental sensing applications: smart agriculture, precision farming, and smart city, to name a few. It consists of hardware products (sensors, data-loggers & gateways, etc.), software services (SenseCAP portal, mobile App, open dashboard), an API for device & data management.
Note
SenseCAP Sensor is fully compliant with LoRaWAN specifications and can be used with standard LoRaWAN gateways. Please choose the corresponding gateway according to the sensor frequency. Seeed also provides SenseCAP LoRaWAN Gateway for you to use with SenseCAP Sensors seamlessly without an extra huge workload for provisioning.
Note
Please email sensecap[at]seeed[dot]cc to request any technical support for this product.
System Architecture
SenseCAP Architecture
SenseCAP Sensor + Other LoRaWAN Gateway Architecture
  • Support LoRaWAN protocol Class A
  • High reliability and stability
  • An ultra-wide 22-bit dynamic range
  • Ultra-wide-distance transmission: 10km in line of sight scene, 2 km in urban scenes
  • Transmission Interval: every 1 hour
  • Battery life ≥ 8 years
  • IP66 enclosure, suitable for outdoor applications
  • Rapid installation and deployment (see the video below)
Applications
  • Smart Agriculture
  • Smart Building
  • Environmental Monitoring
  • Other Wireless Sensing Applications
Specifications
Air Temperature
Range0 to 188000 Lux
Sensitivity0.045 Lux/LSB
Resolution0.045 Lux
General Parameters
Product ModelLoRa-S-AU915-Light Intensity-01
MicrocontrollerUltra-low-power MCU
Support ProtocolBased on LoRaWAN v1.0.2 protocol
LoRa Channel PlanAU915
LoRa Power Output16 dBm (EIRP)
Sensitivity-137.5dBm(SF12, BW125KHz)
Current Consumption5 μA (sleep mode)
120 mA max(active mode)
Communication Distance2 to 10 km (depending on different antennas and environments)
IP RatingIP66
UV Resistanceanti-aging (from rain/sun exposure): UL746C F1
Enclosure MaterialPC
Operating Temperature-40 ℃ to +85 ℃
Operating Humidity0 to 100 %RH (non-condensing)
Device Weight288g
CertificationCE, FCC, RoHS
Battery (Contained in equipment)
Battery Life≥ 3 years (upload data once per hour)
Battery Voltage3.6V
Battery Capacity19Ah (non-rechargeable)
LoRa Frequency
The device is designed with a fixed LoRa channel, which can not be modified by users. The supported channels are as follows. Please refer to this document for how to connect this device with a LoRaWAN gateway.
LoRa Channel Plan
Uplink (MHz)
916.8 - SF7BW125 to SF12BW125
917.0 - SF7BW125 to SF12BW125
917.2 - SF7BW125 to SF12BW125
917.4 - SF7BW125 to SF12BW125
917.6 - SF7BW125 to SF12BW125
917.8 - SF7BW125 to SF12BW125
918.0 - SF7BW125 to SF12BW125
918.2 - SF7BW125 to SF12BW125
917.5 - SF8BW500
Downlink (MHz)
923.3 - SF7BW500 to SF12BW500 (RX1)
923.9 - SF7BW500 to SF12BW500 (RX1)
924.5 - SF7BW500 to SF12BW500 (RX1)
925.1 - SF7BW500 to SF12BW500 (RX1)
925.7 - SF7BW500 to SF12BW500 (RX1)
926.3 - SF7BW500 to SF12BW500 (RX1)
926.9 - SF7BW500 to SF12BW500 (RX1)
927.5 - SF7BW500 to SF12BW500 (RX1)
923.3 - SF12BW500 (RX2)
1Sensorx1
2Bracketx1
3M4 Self-drilling Screwx4
4M3 Self-drilling Screwx2
認証
HSCODE9031499090
USHSCODE9031499000
UPC
EUHSCODE9013101000
COOCHINA
SenseCAP Wireless Light Intensity Sensor - LoRaWAN AU915 MHz
SKU 114992649
SenseCAP Wireless Light Intensity Sensor measures the intensity of light, which is designed in battery-powered and IP66 enclosure for outdoor use, optimized for use cases that need reliable data collection over years.
Note
We have an upgraded version, please refer to SenseCAP S210X.
JPY¥15986.00
product.detail.alsoAdd.title
