製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
The SenseCAP M4 is a compact, fan-cooled edge computing device built around the reComputer X86 Development Board (J4125-08-00-512SSD) V2.0. It is designed for developers, system integrators, and industrial users who need a reliable, low-power hardware platform for deploying edge computing and customized software applications.
Powered by an Intel® Celeron® J4125 quad-core processor with 8GB LPDDR4 memory and a 512GB internal SSD, the SenseCAP M4 delivers solid computing performance in a small form factor. Its flexible software environment supports a wide range of applications, from IoT gateways and edge data processing to industrial control and software-defined networking.
  • Plug and Play: Provide a no-code experience that enables users to finish deployment.
  • Cloud Service: Provide a one-stop cloud service to help users purchase, deploy, manage, and monitor their devices.
  • Excellent Performance: Powered by Intel® Celeron® J4125 (Frequency: 2.0 - 2.7GHz) with 4 cores and 4 threads. Built-in TPM2.0 cryptographic processor and ECC608 crypto chip, high-security authentication, and reliable connectivity.
  • Low Power Consumption: 10w low power consumption, 7.2 kWh per month, cost $1.008 per month (global average kWh price of $0.144/per kWh).
Hardware Overview
SenseCAP M4  runs at a Quad-core Intel® Celeron® J4125 and RP2040 co-processor, equipping dual 2.5GbE interfaces and multiple wireless connectivities, supporting 4K output, carrying sufficient storage capability, and equipment expandability.
High Security
To keep your precious data secure, SenseCAP M4 Built-in TPM2.0 cryptographic processor and ECC608 crypto chip protect devices from external software threats and physical theft.
Powered by the Intel® Celeron® J4125(Frequency: 2.0 - 2.7GHz) and combined with Raspberry pi@ RP2040 32bit Dual-core Arm Cortex M0+ to optimize the SenseCAP M4 performance. Excellent performance allows SenseCAP M4 to process multi-applications reliably and efficiently and provides higher EPS and faster disk write speed(DWS).
SenseCAP M4 device power consumption is only 10W, 7*24 hours running only costs $12.61 per year. Users can deploy more devices with minimal power cost (global average kWh price of $0.144/per kWh).
Rich Accessories
Besides the powerful features of the SenseCAP device itself, SenseCAP has been providing rich accessory choices for users to get the maximum performance. Such as the best sales of high-performance IoT antennas, antenna cables, mounting pads, and lightning arrestors. A SenseCAP-developed waterproof outdoor enclosure that fits the device in the market is also available. It will further enable the possibilities for users to have the gateways placed outdoors, therefore more various LoRaWAN scenarios could come to reality.
Sales Territory
Due to local policy and regulations, China Mainland, Hong Kong, and Macau are considered as restricted areas for selling and deploying the SenseCAP M4, thus any order placed with the shipping destination in said areas will be considered invalid. So please make sure you could use SenseCAP M4 in your region before placing the order.
Specifications
Components
SenseCAP M4
Processor
Coprocessor
Frequency
EU868 Version: 863MHz ~ 870MHz
US915 Version: 902MHz ~ 928MHz
Antenna
LoRa : 3dBi External Antenna with Base
Graphics
Intel® UHD Graphics 600 (Frequency: 250 – 750MHz)
Memory
LPDDR4 8GB
Storage
Internal 512GB SSD
Wireless
Wi-Fi 802.11 a/b/g/n/ac @ 2.4/5 GHz HT160
Networking
Intel®226-V PCIe2.5GbE LAN, Supports Wake-On-LAN, Supports PXE
Audio
Microphone + headphone Combo Connector
USB
USB 2.0 Type-A x2, USB 3.1 Type-A x1, USB 3.1 Type-C x1
Video Interfaces
HDMI2.0a: Up to 4096x2160 @ 60Hz 24bpp / DP1.2a: Up to 4096x2160 @ 60Hz 24bpp
Expansion Slots
M.2(Key B, 2242/2280): SATA III, USB2.0, UIM; M.2 (Key M, 2242/2280): PCIe 2.0 ×4; Micro SD card Socket; SIM Card Socket; SATA III
 Operating temperature
 0°C~45°C
Storage temperature
 -20°C~60°C
TPM
Built-in TPM 2.0
Power
DC Jack 5.5/2.1mm or Type-C PD; DC Jack input: 12-19V DC; Type-C input: 15V DC
Dimensions
130x120x50mm
Certifications
FCC, CE
SenseCAP M4
1
LoRa Antenna
1
User Manual
1
International Power Adapter
1
SenseCAP Sticker
2
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
SenseCAP LoRa Gateway based on reComputer - X86 Development Board (J4125-08-00-512SSD) V2.0 (With Fan) - EU868
SKU 110991884
SenseCAP M4 Square is a device designed to run multiple Web3.0 Apps. No code seamless set up the CUMULUS FluxNode and Helium light hotspot provides scalable, decentralized computational network for Flux and miles of wireless network coverage and data transmission capacity for LoRa/LoRaWAN devices.
JPY¥38745.00
¥48432.00
Save ¥9687.00(20%)
廃番
