Are you eager to find a solution that could increase your gateway coverage?
Are you wondering how to keep your gateways safe when putting them outdoors?
Are you struggling to find a case that could perfectly meet your gateway size and extended interface requirements?
Note
When installing the enclosure, please ensure the panel with holes faces downward to prevent water from entering the holes.
Specially designed for outdoor gateway deployment, the SenseCAP Outdoor Enclosure features a practical size that fits most mainstream gateway devices, making it ideal for various outdoor LoRaWAN® gateway applications.
With multiple types of extended interfaces provided, including 3* N-type female interfaces for LoRa antennas, 1* Ethernet connector with cable gland for Ethernet cable, 1* PG9 interface for power supply, and 1* lightning arrestor ground connector reserved on the bottom cover, SenseCAP Outdoor Enclosure helps you easily connect your gateway with the Ethernet cable, fiberglass antenna, 4G antenna, GPS antenna, solar panel power station, lightning arrestor, and more. The IP66 waterproof rating keeps it safe from dust and water when placed outdoors.
Rich accessories are provided for easy assembly. More possibilities are waiting for you to discover with your gateways! Bring your IoT applications into the wild with SenseCAP Outdoor Enclosure Kit now.
Attention
The working temperature of the outdoor enclosure is -40~85°C. However, users should always keep in mind that it is important to make sure the inner temperature does not exceed the specified working temperature range of each component assembled inside, such as the gateway device, PoE splitter, and battery management controller.
If your placement is in a high-temperature weather area and has a long period of direct sunlight, it is highly suggested to add an additional cover or put the enclosure under the solar panel to prevent overheating damage to the internal device.
Please note that SenseCAP will not be responsible for damage to the internal devices caused by misuse in inappropriate weather conditions or placement.
Note
All cable glands and connectors are not assembled to the enclosure holes, providing users with more flexibility to choose what to use based on different scenarios. Waterproof silicone plugs are provided for the unused holes.
Note
This kit includes the necessary parts to assemble SenseCAP M1/M2 and other gateway devices that fit the enclosure size, but it does not include SenseCAP M1/M2 Gateway, SenseCAP PoE Splitter, or Antenna.
Note
This product does not include an antenna. Please click here to choose antennas and cables.
Specially designed for outdoor gateway deployment, the SenseCAP Outdoor Enclosure offers a practical size that fits most mainstream gateway devices. With reliable protection and easy installation, it is ideal for various outdoor LoRaWAN® gateway applications.
