Sipeed M0sense is an AIOT development board based on BL702 of Bouffalo Lab, it's RISC-V architecture, and supports low-energy Bluetooth. There is an 8Pins FPC connector for connecting the LCD screen, 1 microphone, 1 RGB LED and a six-axis sensor chip on this board. One USB 2.0 FS routes to the Type-C interface.
Sipeed M0Sense is a thumb-sized development board based on the BL702 chip focused on AIOT edge computing development. Although small in size, it can be considered a large capacity in terms of edge computing and machine learning. It will exceed your imagination that can play a powerful performance. The development board is able to run AI Models via TinyMaix&MaixHub then unlock the amazing experience of AIOT edge computing, and support Drag&Drop Update Firmware too.
In addition, it can be used as a miniature machine learning module with a 0.68-inch 80x160 solution screen, 1 microphone, 1 RGB LED and a six-axis sensor chip. You can apply it to handwritten numeral recognition, keyword wake-up, gesture recognition, real-time people-flow counting and many more recognition detection items. With the microphone, you can make sound spectrogram analysis, human posture recognition using IMU, etc. It is a great option for machine learning aspects.
CPU | BL702-32 bits RISC-V with FPU |
Freq | Max 144MHz |
Memory | 132KB RAM,192KB ROM, 512KB Flash |
Interfaces | Two 32-bit timerEight DMA channels
Wireless |
Port | USB 2.0 FS route to USB Type-C to burn firmware |
Onboard components | Screen interface (Optional 0.68 inch 80x160 solution screen) |
1×analog microphone | |
1× RGB LED | |
1×six-axis IMU(QMI8658A) | |
Ceramic antenna | |
Others | |
Dimension | 23mm x 18mm |
Supply Voltage | 5V±10% 0.5A |
LED | RGB Three color |
Model platform | TinyMaix + MaixHub |
Temperature rise: | <30K |
Operating temperature | -10℃ ~ 65℃ |
Sipeed M0sense development board | 1 |
pin header | 1 |
0.68 inch 80x160 solution screen | 1 |
| HSCODE | 8471504090 |
| USHSCODE | 8517180050 |
| UPC | |
| EUHSCODE | 8471707000 |
| COO | CHINA |
