おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
The Snips Voice Interaction Development Kits empowers users to jump start their development of voice interfaces and easily integrate the Snips AI Voice Platform with hardware. Snips runs on device, meaning all of your voice commands and data are processed locally rather than being sent to the cloud. This on-device processing results in a completely secure offline voice assistant that keeps your personal data private, as it should be.
The Voice Interaction Base Kit allows you to run the entire Snips AI Voice Platform. Powered by a Raspberry Pi 3 Model B+ and the ReSpeaker 2-Mics Pi HAT, it is capable of acting as your home smart speaker. Along with the kit comes a speaker, a Grove - Temperature & Humidity Sensor (SHT31), a Grove - Relay, and a pegboard to hang it on a wall or create a nifty stand.
But that's not all! The Voice Interaction Satellite Kit will extend your base station to reach each room of your house and allow you to interact with the hardware based on where you issue your commands!
Check out the video below and get started assembling the Snips Voice Interaction Kit to build your next voice project.
ドキュメント
認証
HSCODE9023009000
USHSCODE8517180050
UPC841454122319
EUHSCODE9023001000
COOCHINA
部品リスト
Electronics
Raspberry Pi3 B+
1
1
Grove – Relay
1
Grove - Temperature&Humidity Sensor (SHT31)
1
Speaker 6Ohm 2W
1
MicroSD Card
1
Power adapter with Micro USB connector
1
Grove cable
2
Acrylic
Acrylic Base panel
1
Acrylic Protective cover for Relay
1
Acrylic Table stand
2
Assembly components
6mm,M2 full thread black hex nylon spacer
3
12mm,M2 full thread black hex nylon spacer
5
25mm,M2 full thread black hex nylon spacer
3
6mm,M2.5 full thread black hex nylon spacer
4
5mm,M2 carbon steel phillips screw
22
5mm,M2.5 nylon phillips screw
8
10mm,M3 carbon steel phillips screw
4
3
Blue rope
1
Screw driver
1
Snips Voice Interaction Base Kit
SKU 110060970
USD$115.00
廃番
product.detail.alsoAdd.title
