おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
SNZB-04 is a Zigbee low-power and intelligent security wireless door and window sensor, it is through the magnet and the transmitter is separated to trigger the transmitter. The transmitter sends a trigger message to the App in time. And can use hand-free Voice control and interacts with Alexa/Google Assistant, an excellent choice for monitoring home security in time or interacting with smart appliances in the home.
Feature
  • Real-time synchronization of data: Check the sensor status through the App to get the latest and most real data. Of course, You can also add a camera to view or scare the stranger off with your voice.
  • Historical data query: You can view all the data for the 90 days/3 months anytime, anywhere, and all the records or data are automatically saved.
  • Hand Free Voice Control: When you are at home not sure if the doors and windows are closed, you can ask your Alexa/ Google Assistant instead of running home right away.
  • Low power consumption and Low battery Reminder: You can check whether the SNZB-04 is in a low battery through the app, or the app will inform you that the Senor is about to run out of battery.
  • Simple installation: DW2-WiFi is installed with 3M adhesive tape and just needs Simple peel-and-stick installation, it is easy to fit in door frames and window sills.
The SONOFF SNZB-04 is a Zigbee 2-in-1 wireless door and window sensor that can be placed on your doors and windows to give you an additional layer of security by giving you an alert notification when your doors and windows are opened or closed. It triggers the transmitter by separating the magnet and the transmitter, then the transmitter sends the trigger message and sends the message to the App in time. This sensor offers you the possibility to create a scene link between Zigbee and WiFi devices. Door/window opening and closing status are synced on your phone, no more thinking about closing/closing. Compared with other door and window sensors of the same type, it can be linked with Alexa/Google Assistant such as whether the window is closed or not.
If you meet a situation where you are worried about whether the doors and Windows of your home are closed after you go out, then Sonoff SNZB-04 can monitor and push messages to the app promptly, ensuring your home is more secure. If you want to check what's going on in your home, you can connect to the SNZB-04 by installing a Sonoff camera or an unused smartphone. And you can receive the alert notification when the door is opened via SNZB-04. Historical operation records support you to query the status of home doors and Windows in the past 3 months, which is convenient for you to track historical information when you are not at home.
If you want to open a door in your home or close a door that can automatically turn on or off the lights in the room, just need to connect Sonoff's SNZB-04 and Sonoff's light to the APP, and could achieve the above function.
Application
  • Smart Home
  • Front door/Back yard
  • Window
  • Office
  • Prison
Product Type
ZigBee Wireless door/window sensor
Battery
3V(CR2032)
Wireless connection
Zigbee
Material
PC
Dimension:
Magnet: 32X15.6X13mm;
Sensor: 47X27X13.5mm
Certified Compliance
FCC, CE, ROHS
Works With
Amazon Alexa, Google Assistant
SNZB-04 Sensor
x1
3M Adhesive Tape
x1
Magnet
x1
User Manual
x1
認証
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE8471707000
COOCHINA
Sonoff SNZB-04 Zigbee Wireless Smart Door/Window Sensor, Smart home,Voice control
SKU 113991080
JPY¥1344.00
廃番
product.detail.alsoAdd.title
