製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
This WioHeliumMonitor is a plug-and-play LongFi hotspot monitor for the Helium network. It makes sure the Hotspot is connected to the LAN and has access to the Internet, you will also be alarmed when it is not working correctly through Grove-Wio-E5.
Feature
  • Long Range Hotspot Monitoring: this product is to monitor your Helium Hotspot in real-time and remotely.
  • plug-and-play: Compact size makes it easier to bring the device anywhere.
  • Reporting misinformation with APP: WioHeliumMonitor reports information locally and remotely with the Watchium application.
  • Alarm to Remind: any problem detected will raise a local alarm sound.
  • Friendly Interface Display: Directly display network and hotspot information on the Wio Terminal screen.
This WioHeliumMonitor is a plug-and-play LongFi hotspot monitor for the Helium network. It will tell you if your hotspot is continuously reachable from the local network/LAN connection is working, as well as if your hotspot is continuously accessing the Internet/Internet connection is working correctly.
With the Grove-Wio-E5 and an activated Watchium Silver/Gold subscription, you can also verify if your hotspot LoRaWAN communication(including Witness) is operational. In case of Internet/LAN communication problems, it will report the problem over LoRaWAN, while some other hotspots around are able to receive it.
What is the Watchium application?
WioHeliumMonitor reports information locally and remotely with the Watchium application. An account on the Watchium application is required. A Free Watchium account is good enough for Lan / Internet connection monitoring. The Silver (1HNT) / Gold (3HNT) version is required for the LoRaWan listed options. This option includes all the LoRaWan communications.
About Wio Terminal
Wio Terminal is compatible with Arduino and Micropython. It is built with an ATSAMD51 microcontroller with wireless connectivity supported by Realtek RTL8720DN. Its CPU speed runs at 120MHz (Boost up to 200MHz). Realtek RTL8720DN chip supports both Bluetooth and Wi-Fi providing the backbone for IoT projects. The Wio Terminal is Highly Integrated with a 2.4” LCD Screen, there is an onboard IMU(LIS3DHTR), microphone, buzzer, microSD card slot, light sensor, and infrared emitter(IR 940nm).
Wio Terminal
Main Chip
Manufacturer Part Number
ATSAMD51P19
Core Processor
ARM® Cortex®-M4F running at 120MHz
Memory
4 MB External Flash, 192 KB RAM
Maximum Speed
200MHz
External Flash
4MBytes
Operating Temperature
-40°C ~ 85°C (TA)
LCD Screen
Resolution
320x240
Display Size
2.4inch
Drive IC
ILI9341
Wireless Connectivity
RTL8720DN
KM4 CPU
ARM® Cortex®-M4F @ 200MHz
KM0 CPU
ARM® Cortex®-M0
Wi-Fi
802.11 a/b/g/n 1x1, Dual Band 2.4GHz & 5GHz
Bluetooth
Support BLE5.0
Built-in Modules
Accelerometer
LIS3DHTR
Microphone
1.0V-10V -42dB
Speaker
≥78dB @10cm 4000Hz
Light Sensor
400-1050nm
Infrared Emitter
940nm
Interface
MicroSD Card Slot
Maximum 16GB
GPIO
40-PIN (Raspberry Pi Compatible)
Supported Protocol
SPI, I2C, I2S, ADC, DAC, PWM, UART(Serial)
Grove
2 (Multifunction), for Digital, Analog, I2C, and PWM
FPC
20-Pins
USB Type-C
Power & USB-OTG
Operation Interface
5-Way Switch
Power/Reset Switch
User-defined button *3
Enclosure
Mouting
Built-in magnets and two mounting holes
Dimension
72mm*57mm*12mm
Materials
ABS+PC
Software Support
Arduino
MicroPython
ArduPy
AT Firmware
Visual Studio Code
CircuitPython ( How to run CircuitPython on Wio Terminal?)
Grove - Wio-E5
Voltage Supply: 3.3V / 5V
Power Output: Up to +20 dBm at 3.3V
Working Frequency868MHz / 915MHz
ProtocolLoRaWAN
Sensitivity-116.5dBm ~ -136dBm
ModulationLong Range , (G)FSK, (G)MSK and BPSK
CurrentOnly 60uA in sleep mode
Size20*40mm
Working Temperature-40℃ ~ 85℃
Partlist
Wio Terminal1
Grove-Wio-E51
FAQ:
if I add a Grove-Wio-E5 to my Wio Field Tester, will it work as WioHeliumMonitor?
Yes, it will. You just need to update the wifi stack
With Wio Terminal+ Wio Helium Monitor E5, you can monitor and alarm your Helium Hotspot as Paul used in the above video!
認証
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE8517180000
COOCHINA
Wio Terminal Helium Monitor Kit: plug-and-play hotspot monitor for helium network
SKU 114992990
JPY¥10921.00
廃番
