製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
This kit is aimed at starters. The functional modules included in this kit are selected especially for a beginner which are frequently required modules, and very cost-effective. The most amazing part of this kit is the Wio Link development board which can be utilized for various devices: without much programming skill required. All the actions you want your modules performed and the flashing-code operation to Wio Link could be completed with taps in a mobile app. And you can send instructions to your devices over Internet at anywhere. So Wio Link will be a perfect utility to make things around smarter for everyone. Now let's enjoy being a maker.
  • Include common frequently-used environment-monitoring functional modules
  • Grove port interfaced, more practical function and less work
  • Completely easy to make things around you smarter and add fun to daily life.
  • Cost-effective
Warning
The Wio IFTTT function is EOL. But Wio APP is available. You can use the API from Wio APP to read sensor status and control the actuator.
認証
HSCODE9023009000
USHSCODE9023000000
UPC841454117384
EUHSCODE9023001000
COOCHINA
技術詳細
Dimensions190mm x120mm x45mm
WeightG.W 260g
BatteryExclude
部品リスト
Grove - Button1
Grove - Relay1
Grove - Temp&Humi Sensor1
Grove - Digital Light Sensor1
Grove - WS2812 Waterproof LED Strip - 30 LEDs 1 meter1
Grove - 3-Axis Digital Accelerometer(±1.5g)1
Wio Link1
Micro USB Cable - 48cm1
Wio Link Starter Kit
SKU 110020051
Specially selected Grove set Plug-n-play with Grove connectors Friendly for starters Designed for IoT application development Cost-effective
JPY¥8531.00
廃番
