おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Supports Meshtastic.
  • Supports over 300 Seeed Grove sensors, making it highly adaptable to various tracking and sensing requirements.
  • Onboard temperature sensor, humidity sensor, and three-axis accelerometer to capture diverse environmental and motion data.
  • A fully open-source platform leveraging the extensive LR1110 and nRF52840 open-source ecosystem for limitless application possibilities.
General
Voltage - supply
5V (USB 2.0 Type-C)
Battery Connector
3.7V
Interface
RFIO
GNSS Antenna Connector* 1
LoRa Antenna Connector* 1
USB type-C
* 1
Grove Interface
ADC* 1I2C* 1UART* 1
Digital*3
Button
USER
Configurable button
RESET
Reset
Exterior FLASH Memory
4M
LoRa® and Positioning with Semtech LR1110 (This Kit Only Use the LoRa® RF transceiver)
LoRaWAN® Protocol
V1.0.4
Frequency Plan
863~928MHz
Sensitivity
-125dBm @125K/SF7
-141dBm @125K/SF12
Output Power
20dBm max @LoRa®
Positioning Technology
GNSS(GPS/BeiDou), WiFi Sniffer
Range
2~10km (Depends on antenna and environment)
Bluetooth (Nordic nRF52840)
Bluetooth
Bluetooth 5.3
Flash
1MB
RAM
256KB
Protocol
Bluetooth LE, Bluetooth mesh, Thread, Zigbee, 802.15.4, ANT and 2.4 GHz proprietary stacks
Output Power
6dBm max @Bluetooth
Onboard Sensors - TH Sensor (SHT41)
Range
Accuracy
Temperature
-40~125°C
± 0.2°C
Humidity
0~100%RH
±1.8%RH
Onboard Sensors - 3-Axis Accelerometer( Not Used)
Range
±2g, 4g, 8g, 16g
Bandwidth
0.5Hz ~ 625Hz
Sensitivity (LSB/g)
1000 (±2g) ~ 83 (±16g)
Hardware overview
Application
If you've built a Meshtastic device with GPS, temperature, and humidity sensors, numerous potential applications await. Use the Meshtastic APP to communicate with low-power, long-range LoRa® devices via your phone. Connect with nearby nodes, participate in group chats, and share geographic locations—all in areas without cellular coverage.
Recommended Use Cases:
  • Asset Tracking: Track the movement and location of your assets and monitor environmental conditions in real-time where the asset is located for better management.
  • Outdoor Adventure: Use the kit to build a Meshtastic device for off-grid communication with your hiking or camping group. The GPS can help track locations, while temperature and humidity sensors can provide real-time environmental data to ensure safety.
  • Environmental Monitoring: Collect and transmit environmental data. Deploy the device in remote areas to monitor and log temperature and humidity over time, contributing to local weather data collection. Use the device to track and monitor environmental conditions in wildlife habitats, aiding in research and conservation efforts.
認証
HSCODE8543709990
USHSCODE8543709860
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
Wio Tracker 1110 Dev Board for Meshtastic
x1
Lithium Battery
x1
3M Round Stickers
x1
SKU 114993370
It is based on the Nordic nRF52840 BLE and Semtech LR1110 LoRa design. Compatible with Meshtastic firmware, it is a plug-and-play development kit for building your low-power Meshtastic tracker devices.
USD$31.90
product.detail.alsoAdd.title
