製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Note:
Note:
  • "114992550" is the old version WM1302 SPI-US915 and has been EOL. "114992967" and "114992969" are the same new WM1302 SPI-US915 version of different production batch, please feel free to choose any of them if you need SPI-US915 version. All US915 WM1302 modules are FCC certificated.
Wio-WM1302 module is a new generation of LoRaWAN gateway module in mini-PCIe form-factor based on Semtech® SX1302. It features extremely low power consumption and outstanding performance.
  • Powered by Semtech® SX1302 baseband LoRa® chip, extremely low power consumption and high performance.
  • Mini-PCIe form factor with the standard 52-pin golden finger, easy to integrate with various gateway devices.
  • Ultra-low operating temperature, no additional heat dissipation needed, reducing the size of LoRaWAN gateway.
  • High sensitivity down to -139 dBm @SF12 with SX1250 TX/RX front-end; TX power up to 26 dBm @3.3V.
  • Certified with CE, FCC. Simplify the final product certification process.
Wio-WM1302 module is a new generation of LoRaWAN gateway module with a mini-PCIe form-factor. Based on the Semtech® SX1302 baseband LoRaWAN® chip, Wio-WM1302 unlocks the greater potential capacity of long-range wireless transmission for gateway products. It features higher sensitivity, less power consumption, and lower operating temperature compared with the previous SX1301 and SX1308 LoRa® chips.
Wio-WM1302 module is CE, and FCC certified, which helps simplify the development and certification process of the LoRaWAN gateway devices.
Wio-WM1302 is designed for M2M and IoT applications and can be widely applied in LPWAN gateway-supported scenarios. It would be a perfect choice for you to significantly reduce the technical difficulties and time consumption when developing the LoRa gateway devices, including the LoRaWAN gateway, etc.
Hardware Overview
Diagram
Pinout
Applications
  • LPWAN Gateway devices development
  • Any long-distance wireless communication application development
  • Long Range and LoRaWAN application learn and research
Specifications
RegionWM1302 (EU868)WM1302 (US915)
Frequency863-870MHz902-928MHz
Sensitivity-125dBm @125K/SF7
-139dBm @125K/SF12
-125dBm @125K/SF7
-139dBm @125K/SF12
TX Power26 dBm (with 3.3V power supply)25 dBm (with 3.3V power supply)
LEDsPower: Green Config: Red TX: Green RX: Blue
Form FactorMini PCIe, 52pin Golden Finger
Power Consumption (SPI version)Standby: 7.5 mA
TX maximum power: 415 mA
RX: 40 mA
Power Consumption (USB version)Standby: 20 mA
TX maximum power: 425 mA
RX: 53 mA
LBT(Listen Before Talk)Support
Antenna ConnectorU.FL
Operating Temperature-40°C to 85°C
Dimensions30 mm (width) × 50.95 mm (length)
CertificationCE, FCC
Wio-WM1302 LoRaWAN Gateway Module *1pcs
FAQs
1. How many versions are there for Wio-WM1302?
There are USB and SPI versions of Wio-WM1302 modules with both US915 and EU868 frequency plan versions.
2. Why are there different SKUs for the same frequency plan?
Different SKUs for Wio-WM1302 modules are created to differentiate minor hardware differences, which were also certificated by CE/FCC.
Wio-WM1302 module SKUs that are with the same frequency plan version will function the same (e.g. 114992967 and 114992969, both SKUs are SPI versions with US915 frequency plan).
Users could choose the module needed based on the frequency plan.
ドキュメント
認証
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
Wio-WM1302 LoRaWAN Gateway Module (SPI) - US915
SKU 114992967
The Wio-WM1302 module is a new generation of LoRaWAN gateway module in mini-PCIe form-factor based on Semtech® SX1302. It features extremely low power consumption and outstanding performance.
USB-US915
JPY¥83.90
