おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Powerful MCU Board: Incorporate the ESP32-S3 32-bit, dual-core, Xtensa processor running at up to 240MHz, mounted multiple development ports, Arduino / MicroPython supported
  • Outstanding RF performance: Supports 2.4GHz WiFi and BLE 5.0 dual wireless communication, support 100m+ remote communication when connected with U.FL antenna
  • Elaborate Power Design: Lithium battery charge management capability, offer 4 power consumption model which allows for deep sleep mode with power consumption as low as 14μA
  • Thumb-sized Compact Design: 21 x 17.8mm, adopting the classic form factor of XIAO, suitable for space limited projects like wearable devices
  • Perfect for Production: Breadboard-friendly & SMD design, no components on the back
Production-Ready Design with Fusion PCBA Support
All Seeed Studio XIAO dev boards feature a production-optimized SMD (Surface Mount Device) design with standardized stamp holes, making it perfect for commercial PCBA (Printed Circuit Board Assembly) integration.
With our Seeed Studio Fusion services, you can access competitive one-stop PCBA manufacturing, component sourcing, and testing, plus free DFA/DFM review to reduce manufacturing risks and accelerate the journey from prototype to production.
Note
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
Starter Kit with free Course for all Electronics Neophytes and Enthusiasts
Seeed Studio has provided the Grove Starter Kit along with free and detailed courses for you quickly get started with microcontrollers and electronics, regarding all the Seeed Studio XIAO boards, promising you a great learning experience.
Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
If you are interested in programming embedded machine learning, we have Codecraft visual programming that can help you quickly start your own TinyML project. And we have set up a #tinyml channel on our Discord server, please click to join for 24/7 making, sharing, discussing, and helping each other out.
We already have 15 XIAO products based on different solutions in the XIAO family, to help you better understand the differences and choose the most suitable part for your projects, please refer to the Seeed Studio XIAO Series Page.
仕様
Parameter
Seeed Studio XIAO ESP32-S3
Seeed Studio XIAO ESP32-C3
Processor
ESP32-S3R8 SoC
ESP32-C3 SoC
Xtensa LX7 dual-core, 32-bit processor running up to 240 MHz
RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz
Wireless
Complete 2.4GHz WiFi subsystem
Bluetooth Low Energy 5.0 / Bluetooth Mesh
On-chip Memory
8MB PSRAM & 8MB Flash
400KB SRAM & 4MB Flash
Interface
1x UART
1x IIC
1x SPI
11x GPIO(PWM)
9x ADC
1x User LED
1x Charge LED
1x UART
1x IIC
1x SPI
11x GPIO(PWM)
4x ADC
1x Charge LED
1x Reset button
1x Boot button
Dimensions
21 x 17.8mm
Power(Typ.)
Input voltage (Type-C): 5V
Input voltage (BAT): 3.7V
Circuit operating Voltage:
- Type-C: 5V@19mA
- BAT: 3.8V@22mA
- USB:5V@9mA
- BAT:3.8V@9mA
Charging current:
50mA(Fast) / 3.8mA(Trickle)
Charging  current:
 380mA(Fast) / 40mA(Trickle)
Low Power Consumption Mode(Typ. )
(Supply Power: 3.8V)
Modem-sleep Model: 27 mA
Light-sleep Model: 2mA
Deep Sleep Model: 14 μA
Modem-sleep Model: 24 mA
Light-sleep Model: 3 mA
Deep Sleep Model: 44 μA
WiFi Enabled Power Consumption(Typ. )
Active Mode: 220 mA
Active Mode: 103 mA
BLE Enabled Power Consumption(Typ. )
Activex Mode: 217 mA
Working Temperature
-40°C ~ 65°C
-40°C ~ 85°C
ハードウェア概要
  • Onboard
*XIAO ESP32 S3 version was not included the B2B connector.
  • PinOut
用途
  • Internet of Things
  • Wearable devices
  • Smart Homes
  • Robotics
  • Health monitoring
  • Education
  • Low-Power(LP) networking
  • Rapid prototyping
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
XIAO ESP32S3
x1
Antenna
x1
7 Pin Header
x2
Note: Starting from September 2024, the overseas warehouses are shipping a mix of old and new stock of Seeed Studio XIAO ESP32S3. Note that the new stock from the CN warehouse comes with Pin Header, while the old doesn't.
We are putting the spotlight on Seeed's self-developed Home Assistant-compatible products, offering affiliates 10% commission on referred sales. Sign up to earn more today!
SKU 113991114
Seeed Studio XIAO ESP32S3 leverages 240MHz Xtensa 32-bit LX7 dual-core processor, supporting both WiFi and BLE 5.0 wireless connectivities and a 2.4GHz Rod antenna. Ideal for the Internet of Things, Smart Homes, Wireless wearable devices, Robotics, etc.
XIAO Dev Board
Pin Header
Package
JPY¥1186.00
product.detail.alsoAdd.title
