The ATmega328PB is backward compatible with the ATmega328 and is not a complete replacement for the latter. Code developed for ATmega328 will work correctly on ATmega328PB.
You can port your projects from the classic Arduino, but you will have more peripheral interfaces:
10 PWM Channels
The ATmega328PB supports hardware touch scanning using a Peripheral Touch Controller (PTC)
For a voltage of 3.3V, a linear stabilizer AMS1117 is used, with a maximum current of up to 800 mA, which allows you to connect more powerful modules, for example, NRF24L01.
