Grove Beginner Kit for Arduino
Grove Beginner Kit for Arduino is creative kits for beginners to get started with Arduino. the main control board Seeeduino Lotus and 8 Grove modules, which covering the sensor, actuator, display and detailed instructions on the use of Arduino and the use of each module, which including 8 lessons for the module and 2 Arduino projects. Check out the video and get to know more!.
Order Now$29.90Grove Base Kit for Raspberry Pi
Grove Base Kit for Raspberry Pi gets you up and running with the Raspberry Pi quickly. This kit includes a Grove Base Hat for Raspberry Pi and 10 Grove modules, which covering sensor, actuator, and display. All you need to do is following the demo, plug the module into the Grove Base Hat, truly plug, play and detailed instructions on the use of Raspberry Pi and the use of each module, which including 8 lessons for the module. Check out the video and get to know more!
Order Now$39.90Grove Inventor Kit for micro:bit
Grove Inventor Kit for Micro:bit brings endless possibilities to your micro:bit. The core board in this kit is the Grove shield for micro:bit. With this shield, you can use plenty of Grove modules including sensors, displays, and actuators to interact with micro:bit. Best of all, there is no need for soldering or jumper wires anymore. Check out the video and get to know more!
Order Now$59.90
Main Boards
Arduino Uno Rev3
The Arduino Uno Rev 3 is a microcontroller board based on the ATmega328, an 8-bit microcontroller with 32KB of Flash memory and 2KB of RAM.
Shop Now -
Raspberry Pi 3 Model B+
Blazing Fast Quad-Core 64-bit CPU and Faster GPU open a new realm of possibilities and applications limited only by your creativity.
Shop Now -
micro:bit Telec version
micro:bit is a tiny programmable computer, pocket-sized microcontroller, designed to make learning and teaching easy and fun!
Shop Now
Shields & Hats
LEDs
Sensors
Motors
Related Base Kits
Don't Miss Out
Get the latest Hardware news, product announcement and deals at Seeed Studio.
