Product Details
Wiki & Learn
Reviews
Download PDF
Feature
⚠️ Buying Guide
The reBot Arm B601-RS is shipped without a 48V 12.5A power supply or a G-clamp. Both are required for normal operation. For teleoperation, you will also need a Star Arm 102 (Leader Arm) and a 12V 2A AC/DC Adapter (5-in-1). If you need any of these accessories, please visit the reBot Arm B601-RS Bundle page, where they can be purchased together.
  • Built for Physical AI — Affordable 6+1-DoF robotic arm for sim-to-real learning.
  • Completely Open — Hardware, software, CAD, SDK, BOM, and algorithms included.
  • Learn Faster — Comprehensive tutorials from assembly to deployment.
  • Always Improving — Free algorithm updates, demos, and learning resources.
  • Precision Motion — ±0.1 mm repeatability powered by RobStride Dynamics motors.
  • Robotics Ecosystem — Compatible with ROS, NVIDIA Isaac Sim, LeRobot, Pinocchio.
  • More Robotics for Less — Professional capabilities at an accessible price.
Join our Discord community for discussions and support:
https://discord.gg/wsfpnbm3cU
One‑Stop Guided Setup & Cloud‑Powered Robot AI Training
SenseCraft Robotics is an in‑house developed, exclusive platform from Seeed Studio. It delivers an all‑in‑one robot‑AI workflow featuring guided setup, cloud training and lightweight local validation. It lets you finish essential pre‑training steps — device pairing, serial binding, camera binding, calibration check and teleoperation check — all in one place, greatly streamlining your setup for education labs, R&D PoCs and early‑stage robot validation projects.
Degrees of Freedom
6+1
Reach
754mm
Joint Range of Motion
J1:±150°
J2:220° - 0°
J3:220° - 0°
J4:±90°
J5:±90°
J6:±180°
Gripper:345° - 0°
Payload
2.5kg
Maximum load
5kg
Repeatability
±0.1mm
Weight
6.5kg
Servos
ROBSTRIDE 06 x3
ROBSTRIDE 00 x4
Operating Temperature
-20°~50°
Power
48V 12.5A
ROS1
Moveit1
ROS2
Moveit2
Python
Lerobot
Isaac Sim
Pinocchio
Pinocchio
Open Source
Hardware Overview
Application
Learn & Build Robotics Easily
Lower the barrier to robotics with step-by-step tutorials. The reBot Arm B601-RS helps you go from assembly to intelligent robot control quickly and confidently.
Research & Laboratory Automation
High-precision robotics for liquid handling, sample transfer, and laboratory workflows. Built for repeatability, delicacy, and rapid experimentation.
Teleoperation & Physical AI
Power real-time control, data collection, and sim-to-real learning with leading robotics frameworks including LeRobot and Isaac Sim. A dexterous “hand” for embodied AI.
Industrial Automation & Logistics
±0.1 mm precision, up to 5 kg payload. The reBot Arm B601-RS enables precision assembly, inspection, sorting, and material handling in manufacturing and warehouse environments. Compact and easy to integrate into existing production lines and workcells.
Certification
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
Assembled Robotic Arm (with gripper)
1
RobStride USB-CAN Driver Board
1
CANABLE
1
XT30 2+2 Power Separation Board
1
Hex key wrench set
1
Mouse pad
1
Wire kits
1
reBot Arm B601-RS (without power supply)
SKU 100019336
Built to be truly open. Featuring a 2.5 kg rated payload and ±0.1 mm repeatability, the reBot Arm B601-RS combines fully open hardware and software with comprehensive tutorials, making sim-to-real learning, teleoperation, and real-world robotics development more accessible than ever.
Robot Arm
Assembly
AI Computing Platform
Kit Type
JPY¥284735.00
