おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
reCamera Pro is now available for pre-order.
The first production batch is expected to arrive at our warehouse in mid-August. Orders will be shipped as soon as inventory becomes available.
Thank you for your support!
Product Overview
reCamera is Seeed Studio’s product family of AI cameras, designed to bring intelligent vision capabilities to the edge. The current reCamera product portfolio is shown below.
reCamera Pro is an advanced edge AI camera that combines computer vision, multi-modal perception, and flexible automation workflows in one compact device. It runs AI models locally, from YOLO-based object detection to LLM, VLM, STT, and TTS models, enabling responsive AI inference directly at the edge.
Designed for customizable AI applications, reCamera Pro supports diverse triggers including AI detection, audio events, GPIO signals, HTTP requests, UART commands, and scheduled tasks. With industry-standard protocols including RTSP, ONVIF, MQTT, HTTP, and UART, it seamlessly integrates with existing NVR, PLC, and IoT systems.
With an 8MP starlight sensor, interchangeable lenses, built-in microphones, IMU sensors, SenseCraft AI, and an intuitive Web UI, reCamera Pro empowers developers to quickly build, customize, and deploy intelligent edge AI applications — from AI vision prototypes to real-world automation solutions.
Built around the Rockchip RV1126B AI SoC, reCamera Pro is a powerful Edge AI Camera capable of running a wide range of AI models locally. With a 3 TOPS NPU and quad-core Arm Cortex-A53 CPU, it delivers real-time inference for computer vision tasks (such as object detection, classification, and recognition), VLM, LLM and speech AI applications.
Run different AI Models Locally
Supported AI models include:
  • Computer Vision Models (YOLO)
  • Vision Language Models (VLM)
  • Large Language Models (LLM)
  • Speech-to-Text (STT)
  • Text-to-Speech (TTS)
AI Performance Benchmark
  • Vision CNN: YOLO11 @ 43 FPS (640 × 640)
  • LLM: Qwen2 0.5B (W8A8) — 13.63 tokens/s
  • VLM: InternVL3-1B — 6.08 tokens/s
  • STT: Whisper Base with real-time support (RTF ~0.40–0.50)
  • TTS: MMS-TTS with real-time support (RTF ~0.09–0.18)
Compatible with Popular AI Frameworks
Support for ONNX, PyTorch, TensorFlow Lite, Caffe, and Darknet, with RKNN-Toolkit2 for efficient model conversion and deployment.
Feature 2:Enable Multi-Modal Sensing for Smarter Event Detection
Vision alone isn't always enough to fully understand real-world events. By combining audio and external sensor data with visual information, AI can gain richer context for more accurate event understanding. reCamera Pro combines vision, audio, motion, and external sensor inputs to understand real-world events from multiple perspectives.
With built-in dual microphones, IMU, and expandable GPIO and UART interfaces, it enables multi-modal AI applications beyond traditional camera-based detection
Intelligent Event Detection with Multiple Inputs
Dual Microphones
Enable always-on audio monitoring for intelligent event triggering.
Detect events such as:
  • Glass breaking
  • Abnormal impact sounds
  • Custom voice keywords (e.g., "Hands Up")
Built-in IMU
Monitor vibration, movement, and orientation changes in real time.
Applications like:
  • Device Impact Detection
  • Shock Event Alerts
  • Device Orientation Monitoring
GPIO & UART Sensor Expansion
Connect external sensors and devices to expand AI applications, like:
  • CO2 sensor
  • Temperature sensor
  • Radar sensor
  • Human presence sensors
  • more...
Turn AI perception into automated actions with flexible event-driven workflows. reCamera Pro works not only as a standard IPC camera, but also as an intelligent edge device that responds to AI detection results, audio events, sensor inputs, and external commands. Define custom triggers and actions to automate different scenarios without additional controllers.
Flexible Trigger Sources
Supported triggers:
  • AI Detection
  • Audio Event
  • Sensor Event
  • GPIO
  • UART
  • HTTP Command
  • Timer
Customizable Actions
Supported actions:
  • Capture Image
  • Record Video
  • Play Audio
  • HTTP Callback
  • MQTT Publish
  • RTSP Streaming
  • Save to NVR
  • Send Alert
Configure, deploy and monitor your AI camera directly through a browser—without complicated development tools.
The built-in Web UI simplifies device setup, AI model management, workflow configuration, and system maintenance.
Web-Based Management Features
Support:
  • Main Stream / Sub Stream Configuration
  • AI Workflow Configuration
  • Model Output Management
  • Device Monitoring
  • Terminal Management
  • Privacy Mask Configuration
  • System Settings
Feature 5 :Build Custom AI Models in 1 Minute with No Code and Few Samples
With SenseCraft AI, a no-code AI training platform in the SenseCraft AIoT ecosystem, reCamera Pro makes custom AI model development simple. Train, convert, and deploy custom vision and sound classification models with no code and only a few samples. These models can be adapted to a wide range of real-world applications, allowing AI to learn the visual and audio patterns that humans naturally recognize.
Vision classification models
Vision classification models can learn many of the visual judgments humans make every day. By training with your own examples, reCamera Pro can recognize differences in appearance, quality, condition, and categories—enabling applications such as quality grading, object classification, scene recognition, and custom inspection tasks.
Create Models Like:
  • Inventory Status Recognition
  • Queue Status Recognition
  • Material Level Monitoring
Sound classification models
Sound classification models enable AI to recognize the sounds humans naturally identify—what a sound is and whether it is normal or unusual.
Applications include:
  • Glass breaking, alarms, horns, dog barking, and emergency keywords such as “Help”
  • Machine abnormal noise and equipment condition monitoring
  • Cough pattern and voice condition analysis
  • Custom sound event recognition
With reCamera Pro, you can combine audio and vision for richer, more intelligent analysis.
In addition to rapid model training, SenseCraft AI streamlines the deployment workflow
  1. One-click ONNX model conversion and optimization for Edge AI deployment
  2. Many ready models for deploy
Feature 6 :Seamlessly Integrate with Existing Systems
Connect reCamera Pro with your existing infrastructure through widely adopted industrial and security protocols.
Designed for integration with video management systems, PLC automation, and IoT platforms, reCamera Pro helps accelerate AI deployment without replacing your current systems.
Supported Protocols
  • RTSP, RTMP, ONVIF, HTTP, MQTT, UART, CAN
Can be Used with:
  • Video Management Systems (VMS)
  • NAS
  • Network Video Recorders (NVR)
  • Smart Buildings
  • PLC Automation Systems
  • Factory Automation
  • IoT Platforms
It also works with Frigate & Home Assistant.
Feature 7 :Easy Development with Flexible APIs
Access the full capabilities of reCamera Pro through standard HTTP APIs.
Developers can remotely control devices, retrieve AI results, manage workflows, and integrate camera functions into applications without relying on proprietary communication protocols.
Check API on Wiki
Feature 8 :Support Flexible Camera Lens Options for Diverse Applications
Adapt your Edge AI Camera to different environments with flexible lens configurations.
reCamera Pro supports:
  • M12 Lens
  • CS Mount
  • C Mount
Feature 9: Build Vision Automation with Natural Language Commands
Transform natural language instructions into automated camera workflows. reCamera Pro is powerful enough to install lightweight agent like NanoBot, PicoClaw, ZeroClaw, without manually creating complex automation logic.
reCamera Pro provides an official API Skill that packages camera controls, AI inference results, and common device functions into Agent-ready tools.
Examples:
  • Send me a message if someone walks by.
  • Take a photo when you see a cat.
  • Start recording if someone enters the area.
仕様
Al Performance
3TOPS @ INT8
SOC
RV1126B
CPU
Quad-core Arm Cortex-A53 processor
MCU
RISC-V MCU as Co-processor
Memory
2GB/4GB
eMMC
16GB
Operating System
Buildroot
Video Codec
Supports 4K@45fps H.264/H.265 encoding and 4K30 decoding
Camera Sensor
SC850SL
Optical Format
1/1.8-inch, starlight-level
Pixels
8MP
Pixel Size
2.0μm
Resolution
3840×2160
Max Frame rate
4k30fps
Output Format
RAW,MP4,JPG
lens mount
M12 x 0.5mm
Focal Length
2.75mm
Aperture
F2.4
FOV
123°±5°
Minimum Focus Distance
0.6m ~ Infinity
Focus Distance(DOF)
2.7m
Ethernet
1000Mbps
Wireless
Wi-Fi 2.4G/5G WIFI 5.0 Bluetooth 5.4
USB
USB Type-C(3.0)
Expansion
removable TF card (up to 512GB, not included)
CSI
Supports 2-channel 4-wire MIPI-CSI interfaces
Output Port
2 x CAN
2 x GPIO
1 x UART
1 x Debug UART
1 x MIPI DSI
Button
A custom button
Status Light
Power indicator light*1, Status indicator light*1
Fill Light
Mic
mic * 2
Speaker
Built-in speaker
Dimension
67*67*89.8mm
Power Supply
12V 2A (DC), POE, TYPE-C, Battery(7.4V)
Weight (Net)
324g±1g
ハードウェア概要
用途
  • Smart Retail
  • Gas Station Security
  • Elderly Fall Detection & Care
  • Smart Factory Quality Inspection
  • Smart Access Control with Face & PPE Recognition
  • Night-Time Warehouse Security Monitoring
  • Construction Site Sandbag Counting & Tracking
ドキュメント
認証
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
部品リスト
reCamera Pro
x1
Power Adapter (UK)
x1
Type-C Data Cable
x1
reCamera Pro 4GB - Open AI Camera, More than Just "People Detection"
SKU 100034201
Powered by the Rockchip RV1126B with a 3 TOPS NPU, it runs computer vision, VLM, LLM, and speech AI directly at the edge. With 8MP starlight imaging, one-click AI model training, built-in Web UI, event-driven workflows, open HTTP APIs, and broad industrial protocol support, reCamera Pro enables rapid development and deployment of intelligent AI solutions for smart security, industrial automation, and IoT applications.A powerful Edge AI camera that can see, hear, sense, and understand the physical world.
reCamera Pro (2GB)
JPY¥55380.00
product.detail.alsoAdd.title
