Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
If you want to use SSDs with reComputer, we only recommend you choose the 128GB, the 256GB, and the 512GB versions from Seeed, because some of the SSDs in the market will work with this product under a particular JetPack version and some will not work with a different JetPack version. Even the official NVIDIA dev kits have the same behavior with SSDs.
Jetson Xavier NX System on Module
AI Performance
reComputer Industrial J2012 - Xavier NX 16GB, 21 TOPS
reComputer Industrial J2011- Xavier NX 8GB, 21 TOPS
GPU
384-core NVIDIA Volta™ GPU with 48 Tensor Cores
CPU
6-core NVIDIA Carmel ARM®v8.2 64-bit CPU, 6MB L2 + 4MB L3
Memory
16GB 128-bit LPDDR4x59.7GB/s (Xavier NX 16GB)
8GB 128-bit LPDDR4x 59.7GB/s (Xavier NX 8GB)
Video Decode
2x 8K30 | 6x 4K60 | 12x 4K30 | 22x 1080p60 | 44x 1080p30 (H.265)
Video Encode
2x 4K60 | 4x 4K30 | 10x 1080p60 | 22x 1080p30 (H.265)
Carrier Board
Storage
M.2 Key M PCIe Gen4.0 SSD (M.2 NVMe 2280 SSD 128G included)8G included)
Networking
Ethernet
1x LAN1 RJ45 GbE PoE(PSE 802.3 af 15 W)
1x LAN2 RJ45 GbE (10/100/1000Mbps)
Wi-Fi
Support SMD Wi-Fi/Bluetooth (Customized production, please contact [email protected])
M.2 Key B
M.2 Key B support 4G/5G (Module optional)
I/O
USB
3x USB3.2 Gen1, 1x USB2.0 Type C(Device mode), 1x USB2.0 Type C For Debug UART & RP2040
DI/DO
4x DI, 4x DO, 3x GND_DI, 2x GND_DO, 1x GND_ISO, 1x CAN
COM
1x DB9 (RS232/RS422/RS485)
Display
1x HDMI 2.0 Type A
SIM
1x Nano SIM card slot
Wi-Fi
Support SMD Wi-Fi/Bluetooth (Module optional)
M.2 Key B
Fan
Fanless, passive heatsink1x Fan connectors(5V PWM)
TPM
1x TPM 2.0 connector (Module optional)
RTC
1x RTC socket, 1x RTC 2-pin
Camera
2x CSI (2-lane 15pin)
Power
Power Supply
DC 12V-24V Terminal block 2 pin
Power Adapter
19V Power Adapter(without power cord)
Mechanical
Dimensions (W x D x H)
159mm x 155mm x 57mm
Weight
1.57kg
Installation
Desk, DIN rail, wall-mounting, VESA
Environment
Operating Temperature
-20 ~ 60°C with 0.7m/s
Operating Humidity
95% @ 40 °C (non-condensing)
Vibration
3 Grms @ 5 ~ 500 Hz, random, 1 hr/axis
Shock
50G peak acceleration (11 msec)
Warranty
2 Years
Hardware Overview
Full System
Carrier Board
Desktop, Wall Mount, DIN Rail, VESA mount to fit in anywhere
Application
Application Fields:
AI Video Analytics
Machine Vision
Autonomous Mobile Robot (AMR)
Generative AI
● Capable of Bringing Generative AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
● Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) .
● Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8, and others. We have configured all environment for you to provides single command deployment of projects.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
reComputer Industrial J2011 (System Installed)
x1
Mounting bracket
x2
DIN rail bracket
x1
Bracket screw
x4
16-Pin Terminal Block for DIO
x1
19V Power adapter (power cord sold separately)
x1
2-Pin Terminal block power connector
x1
Note:
Please note that the product comes with a power adapter, but does not include a AC cloverleaf power cord. Kindly purchase the appropriate AC cloverleaf power cord based on your local power socket specifications.
reComputer Industrial J2011 - Fanless Edge AI Device with Jetson™ Xavier NX 8GB module
SKU 110110188
reComputer J20 has been discontinued due to EOL of NVIDIA® Jetson Xavier™ NX modules. Please migrate to NVIDIA® Jetson Orin™ Nano/NX plaform per NVIDIA suggestions. See reComputer Industrial J3011 or reComputer Industrial J4011 for more details.
reComputer Industrial J2011 features NVIDIA Jetson Xavier NX 8GB module for 21 TOPS AI performance and supports hybrid connectivities including 2x RJ-45 Ethernet ports, 1x RS232/422/485 & CAN port, etc. Fanless with versatile mounting options allows deployment for more harsh environments and heavier loads.
Processor
Memory
JPY¥158116.00
