製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
  • We provide SD card function on reComputer J101 carrier board, which supports CLK Frequency 48MHz. The CLK here is designed to achieve certificates (such as CE/FCC). If you want to increase CLK by yourself, you can use the instructions here.
  • The later reComputer J1010 carrier board version has all SD card functions.
  • J101 carrier board is exactly the same size as the carrier board of NVIDIA Jetson Nano B01 dev kit. However, it's not compatible with NVIDIA Jetson Nano A01 dev kit.
仕様
Carrier Board
Storage
1x Micro SD card slot (48MHz CLK Frequency)
Networking
Ethernet
1x Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E PCIe 2230
I/O
USB
1x USB Type-C (Power In)
1x USB 3.0 Type-A (5 Gbps)
2x USB 2.0 Type-A
1x USB Type-C (Device mode)
Camera
2x CSI
Audio
1x 3.5 Audio Jack
2x MIC
2x SPEAKER
1x SPEAKER FEEDBACK
Display
1x HDMI
Fan
1x Fan Connector (5V PWM)
Multifunctional Port
1x 40-Pin
1x 12-PIn
RTC
1x RTC 2-pin
1x RTC socket(reserved)
Power
5V/3A (USB Type C)
Mechanical (W x D x H)
100mm x 80mm
Operating Temperature
-25℃~65℃
ハードウェア概要
Comparison with NVIDIA Nano series Dev kits carrier board
Note: If you want to use SSDs with reComputer Jetson, we only recommend you choose 128GB, 256GB, and 512GB versions from Seeed, because some of the SSDs in the market will not work with this product.
用途
Application Fields:
  • Autonomous Mobile Robot (AMR)
  • AI Video Analytics
  • Machine Vision
  • Generative AI
認証
HSCODE8543909000
USHSCODE8517180050
UPC
COOCHINA
部品リスト
reComputer J101 Carrier Board
x1
reComputer J101 Carrier Board for Jetson Nano
SKU 102991694
reComputer J101 carrier board is a cost-effective and interface-rich NVIDIA Jetson Nano compatible carrier board. It included HDMI2.0, 2x USB 2.0, 1x USB 3.0, micro SD card slot, 2 xCSI, M.2 key E WIFI / BT, GPIO, I2C, I2S, Fan, and other rich peripheral interfaces. It has nearly the same functional design and exactly the same size as the carrier board of NVIDIA® Jetson Nano™ B01 Developer Kit.
Series
Power Adapter
Supported Processor
JPY¥10921.00
