おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note
  • For optimal performance with reComputer, we recommend using 128GB / 256GB / 512GB / 1TB SSDs from Seeed. Since some SSDs on the market may only be compatible with specific JetPack versions which may cause the device to fail to function properly, and this issue is also present with official NVIDIA dev kits.
  • If you are looking for the version without power adapter, please check out reComputer J2021 without power adapter.
仕様
Jetson Xavier NX System on Module
AI Performance
reComputer J2022, Xavier NX 16GB
reComputer J2021, Xavier NX 8GB
GPU
384-core NVIDIA Volta™ architecture GPU with 48 Tensor Cores
CPU
6-core NVIDIA Carmel Arm®v8.2 64-bit CPU 6MB L2 + 4MB L3
Memory
16 GB 128-bit LPDDR4x 59.7GB/s
8GB 128-bit LPDDR4x 59.7GB/s
Storage
16 GB eMMC 5.1
Video Encoder
2x 4K60 | 4x 4K30 | 10x 1080p60 | 22x 1080p30 (H.265)
Video Decoder
2x 8K30 | 6x 4K60 | 12x 4K30 | 22x 1080p60 | 44x 1080p30 (H.265)
Carrier Board
Storage
1x M.2 Key M PCIe
Networking
Ethernet
1x RJ45 Gigabit Ethernet Connector (10/100/1000)
M.2 KEY E
1x M.2 Key E
I/O
USB
4x USB 3.1 Type A Connector;
1x USB Type-C (Device mode)
CSI Camera
2x CSI Camera (15 pos, 1mm pitch, MIPI CSI-2 )
Display
1x HDMI Type A; 1x DP
Fan
1x FAN connector(5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
RTC
RTC 2-pin
RTC socket
Power
9-16V DC
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 58.5mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃
Warranty
1 Year
ハードウェア概要
reComputer J202 carrier board, included in the full system - reComputer J2021
Desktop, Wall Mount, Expandable, or Fit in Anywhere
用途
  • Autonomous Mobile Robot (AMR)
  • AI Video Analytics
  • Machine Vision
1. What is the main difference between the reComputer J2021 and J2022?
The difference between them is memory. The module on the reComputer J2021 is Jetson Xavier 8GB. If you require more memory, the J2022 with Jetson Xavier 16GB may meet your needs.
2. Can I install the Jetson Nano module on the reComputer J2022 carrier board?
Yes, the reComputer J2022 carrier board J202 supports both the Jetson Nano module and the Jetson Xavier module.
3. What type of RTC is recommended for RTC socket?
CR1220 and ML1220. The non-rechargeable design of the RTC circuit of the carrier board allows both rechargeable and non-rechargeable RTC batteries to be used.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471800000
COOCHINA
部品リスト
Acrylic Cover
1x
Aluminium Frame
1x
Jetson Xavier NX module
1x
Aluminum heatsink with fan
1x
Carrier board
1x
12V/5A(Barrel Jack 5.5/2.5mm) Power Adapter (Power cable not included)
1x
We will not include a power cord, please choose a suitable form according to your country.
We will not include a 3V RTC battery (CR1220)
Note
  • We have already installed JetPack 5.1.1 system in the reComputer and you can directly use it by powering on.
  • Please check our wiki for reflashing Jetpack and expanding the storage.
  • We'd like to hear from you, welcome to join our Discord channel to share your thoughts (Jetson edge AI)
reComputer J2021 - Edge AI Computer with NVIDIA® Jetson Xavier™ NX 8GB
SKU 110061381
reComputer J20 has been discontinued due to EOL of NVIDIA® Jetson Xavier™ NX modules. Please migrate to NVIDIA® Jetson Orin™ Nano/NX plaform per NVIDIA suggestions. See reComputer J3011 or reComputer J4011 for more details.
A hand-size edge AI device with NVIDIA Jetson Xavier NX 8GB SoM, pre-built Jetpack 5.1.1, 4x USB 3.2, HDMI, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
Processor
Memory
Power Adapter
JPY¥88475.00
product.detail.alsoAdd.title
Customize Design reComputer
