製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
Note
  • The reComputer J3010 is equipped with the same NVIDIA Jetson Orin Nano 4GB production module. You can perform a self - upgrade to Jetpack 6.2. Once upgraded, you'll instantly experience a significant boost in computing power, with the performance leaping from 20 Tops to 34 Tops, offering capabilities comparable to those of the NVIDIA Jetson Orin Nano Super Developer Kit.
  • For optimal performance with reComputer, we recommend using 128GB / 256GB / 512GB / 1TB SSDs from Seeed. Since some SSDs on the market may only be compatible with specific JetPack versions which may cause the device to fail to function properly, and this issue is also present with official NVIDIA dev kits.
  • If you are looking for the version without power adapter, please check out reComputer J3010 Edge device
reComputer J3010 (original with JP5.1.3)
reComputer J3010 (super with JP6.2)
GPU
NVIDIA Ampere architecture
512 CUDA Cores
16 Tensor Cores
635 MHz
NVIDIA Ampere
architecture
512 CUDA Cores
16 Tensor Cores
1,020MHz
AI PERF
20 INT8 TOPS (Sparse)
10 INT8 TOPS (Dense)
34 TOPS (Sparse)
17 TOPS (Dense)
CPU
6-core Arm Cortex-
A78AE v8.264-bit CPU
1.5 GHz
6-core Arm Cortex-
1.7 GHz
Memory
8GB 128-bit LPDDR5
68GB/s
8GB 128-bit LPDDR5
102GB/s
MODULE POWER
7W|10W
7W|10W|25W
仕様
Jetson Orin Nano System on Module
AI Performance
reComputer J3011, Orin Nano 8GB - up to 67 TOPS
reComputer J3010, Orin Nano 4GB - up to 34 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores (Orin Nano 8GB)
512-core NVIDIA Ampere architecture GPU with 16 Tensor Cores (Orin Nano 4GB)
CPU
6-core Arm® Cortex®-A78AE v8.2 64-bit CPU 1.5MB L2 + 4MB L3
Memory
8GB 128-bit LPDDR5 68 GB/s (Orin Nano 8GB)
4GB 64-bit LPDDR5 34 GB/s (Orin Nano 4GB)
Video Encoder
1080p30 supported by 1-2 CPU cores
Video Decoder
1x 4K60 (H.265) | 2x 4K30 (H.265) | 5x 1080p60 (H.265) | 11x 1080p30 (H.265)
Carrier Board
Storage
M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E(pre-installed 1x Wi-Fi/Bluetooth combo module)
I/O
USB
4x USB 3.2 Type-A (10Gbps), 1x USB2.0 Type-C (Device Mode)
CSI Camera
2x CSI (2-lane 15pin)
Display
1x HDMI 2.1
Fan
1x 4 pin Fan Connector (5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC
RTC 2-pin, supports CR1220 but not included
Power Supply
9-19V DC
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 58.5mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃
Warranty
1 Years
ハードウェア概要
reComputer J401 carrier board, included in the full system - reComputer J3010
Desktop, Wall Mount, Expandable, or Fit in Anywhere
用途
Application Field
  • AI Video Analytics
  • Machine Vision
  • Robotics
Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8; and others. We have configured all environment for you to provides single command deployment of projects.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer J3010 (System Installed)
x1
12V/5A(Barrel Jack 5.5/2.5mm) Power Adapter (Power cord not included)
x1
Note:
Please note that the product comes with a power adapter, but does not include a AC cloverleaf power cord. Kindly purchase the appropriate AC cloverleaf power cord based on your local power socket specifications.
reComputer J3010 - Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 4GB (Support Super Mode)
SKU 110110146
Powerful and compact edge AI device with NVIDIA® Jetson Orin™ Nano SoM, delivering 20 TOPS AI performance, up to 40X the performance of NVIDIA® Jetson Nano™ and sets the new baseline for entry-level. reComputer J3010 is pre-built Jetpack 5.1.1(super with JP6.2), 128GB SSD, 4x USB 3.2, HDMI, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
Wireless
Processor
Memory
JPY¥102720.00
Customize Design reComputer
