おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
Note
  • reComputer J3011 is powered by the same NVIDIA Jetson Orin Nano 8GB production module.You can perform a self - upgrade to Jetpack 6.2. Once upgraded, you'll instantly experience a significant boost in computing power, with the performance leaping from 40 Tops to 67 Tops, offering capabilities comparable to those of the NVIDIA Jetson Orin Nano Super Developer Kit.
  • For optimal performance with reComputer, we recommend using 128GB / 256GB / 512GB / 1TB SSDs from Seeed. Since some SSDs on the market may only be compatible with specific JetPack versions which may cause the device to fail to function properly, and this issue is also present with official NVIDIA dev kits.
  • If you are looking for the version with power adapter, please check out reComputer J3011 with power adapter
reComputer J3011 (original with JP5.1.3)
reComputer J3011 (super with JP6.2)
GPU
NVIDIA Ampere architecture
1,024 CUDA Cores
32 Tensor Cores
635 MHz
NVIDIA Ampere
architecture
1,024 CUDA Cores
32 Tensor Cores
1,020MHz
AI PERF
40 INT8 TOPS (Sparse)
20 INT8 TOPS (Dense)
67 TOPS (Sparse)
33 TOPS (Dense)
CPU
6-core Arm Cortex-
A78AE v8.264-bit CPU
1.5 GHz
6-core Arm Cortex-
1.7 GHz
Memory
8GB 128-bit LPDDR5
68GB/s
8GB 128-bit LPDDR5
102GB/s
MODULE POWER
7W|15W
10W|15W|25W
仕様
Jetson Orin Nano System on Module
AI Performance
reComputer J3011 - Jetson Orin Nano 8GB, up to 67 TOPS
reComputer J3010 - Jetson Orin Nano 4GB, up to 34 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores (Orin Nano 8GB)
512-core NVIDIA Ampere architecture GPU with 16 Tensor Cores (Orin Nano 4GB)
CPU
6-core Arm® Cortex®-A78AE v8.2 64-bit CPU 1.5MB L2 + 4MB L3
Memory
8GB 128-bit LPDDR5 68 GB/s (Orin Nano 8GB)
4GB 64-bit LPDDR5 34 GB/s (Orin Nano 4GB)
Video Encoder
1080p30 supported by 1-2 CPU cores
Video Decoder
1x 4K60 (H.265) | 2x 4K30 (H.265) | 5x 1080p60 (H.265) | 11x 1080p30 (H.265)
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E(pre-installed 1x Wi-Fi/Bluetooth combo module)
I/O
USB
4x USB 3.2 Type-A (10Gbps), 1x USB2.0 Type-C (Device Mode)
Camera
2x CSI (2-lane 15pin)
Display
1x HDMI 2.1
Fan
1x 4 pin Fan Connector (5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC
1x RTC 2-pin, supports CR1220 but not included
Power
9-19V DC
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 58.5mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃
Warranty
1 Year
ハードウェア概要
  • Desktop, Wall Mount, Expandable, or Fit in Anywhere
用途
Application Fields:
AI Video Analytics
Machine Vision
Autonomous Mobile Robot (AMR)
Generative AI
● Capable of Bringing Generatie AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
● Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin Nano incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) reComputer J3011 can take 11x1080p30 streams. See our tested YOLOv8 performance using NVIDIA Deepstream of single model and multi model on multi streams.
● Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8; and others. We have configured all environment for you to provides single command deployment of projects.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer J3011 (System Installed)
x1
reComputer J3011 (w/o power adapter) - Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 8GB (Support Super Mode)
SKU 110110186
Powerful and compact edge AI device with NVIDIA® Jetson Orin™ Nano SoM, pre-built Jetpack 5.1.1(super with JP6.2), 128GB SSD, 4x USB 3.2, HDMI, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
[Discount on First 5 Only] From the 6th unit onward, the original price will apply.
Series
Wireless Connector
Processor
Memory
Power Adapter
GMSL
JPY¥111868.00
¥117756.00
Save ¥5888.00(5%)
product.detail.alsoAdd.title
