おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note
  •  reComputer Super J4012 comes with Jetson Orin NX 16GB module, delivers up to 157 TOPS in MAXN Super Mode.
  • If you are looking for the version without power adapter, please check out reComputer J4012 without power adapter
  • For optimal performance with reComputer, we recommend using 128GB / 256GB / 512GB / 1TB SSDs from Seeed. Since some SSDs on the market may only be compatible with specific JetPack versions which may cause the device to fail to function properly, and this issue is also present with official NVIDIA dev kits.
仕様
Jetson Orin NX System on Module
AI Performance
reComputer J4012 - Orin NX 16GB, 100 TOPS
reComputer J4011- Orin NX 8GB – 70 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
CPU
8-core Arm® Cortex®-A78AE v8.2 64-bit CPU (Orin NX 16GB)
6-core Arm® Cortex®-A78AE (Orin NX 8GB)
Memory
16GB 128-bit LPDDR5 (Orin NX 16GB)
8GB 128-bit LPDDR5 (Orin NX 8GB)
Video Encode
1x 4K60 (H.265) | 3x 4K30 (H.265) | 6x 1080p60 (H.265) | 12x 1080p30 (H.265)
Video Decode
1x 8K30 (H.265) | 2x 4K60 (H.265) | 4x 4K30 (H.265) | 9x 1080p60 (H.265) | 18x 1080p30 (H.265)
DL Accelerator
2x NVDLA v2
1x NVDLA v2
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module(module not included)
I/O
USB
4x USB 3.2 Type-A (10Gbps)
1x USB2.0 Type-C (Device Mode)
Camera
2x CSI (2-lane 15pin)
Display
1x HDMI 2.1
Fan
1x 4 pin Fan Connector (5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC
1x RTC 2-pin, supports CR1220 (not included)
Power
9-19V DC
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 58.5mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃
Warranty
1 Year
ハードウェア概要
  • Desktop, wall Mount, expandable, or fit in anywhere
用途
Designed for Developers — Out-of-the-Box Experience
Whether you're an experienced developer or a complete beginner for embedded AI/GPU inference, use reComputer Super AI box as your first AI workstation, together diving into NVIDIA Jetson for Beginners — your fast track to vision AI, Generative AI, and robotics development! Through these tutorials, you will learn:
  • From Zero to Real Projects: Master Linux basics on the Jetson environment to build an end-to-end AI NVR/AMR.
  • Hardware Integration: Tailored for reComputer Jetson devices for a seamless, out-of-the-box experience.
  • Coverage of Cutting-Edge Domains: Deep dive into CV, GenAI, ROS, agentic AI, and TensorRT optimization.
  • Toolchain Mastery: Hands-on tutorials with NVIDIA JetPack SDK, CUDA, DeepStream, PyTorch, and TensorFlow.
One-line deployment
To improve the developer experience, Seeed offers reComputer AI Lab — a platform that helps you deploy AI applications with one-click tools and ready-to-use resources. It includes optimized latest edge AI model demos for CV, LLM, VLM, interactive tutorials, deployment tools, containerized applications, and community projects to speed up development on Jetson.
Tool for Developers
Seeed Jetson Develop Tool is a desktop client for all developers who are going to use reComputer Jetson device for the very first time. It brings the common bring-up and development workflow into one GUI: firmware flashing, first-boot initialization, device diagnostics, remote development, app deployment, skill-based automation, OTA updates, and community resources. All we provide here is to help you to get started with Seeed reComputer Jetson hardware much more easily and seamlessly.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer J4012 (System Installed)
x1
12V/5A(Barrel Jack 5.5/2.5mm) Power Adapter (Power cord not included)
x1
Note:
Please note that the product comes with a power adapter, but does not include a AC cloverleaf power cord. Kindly purchase the appropriate AC cloverleaf power cord based on your local power socket specifications.
reComputer J4012 - Edge AI Computer with NVIDIA® Jetson™ Orin™ NX 16GB (Super Mode NOT Supported)
SKU 110110145
Powerful and compact edge AI device with NVIDIA® Jetson Orin™ NX SoM, pre-built Jetpack 5.1.1, 128GB SSD, 4x USB 3.2, HDMI, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
[Discount on First 5 Only] From the 6th unit onward, the original price will apply.
Wireless
Processor
Memory
JPY¥214777.00
¥221425.00
Save ¥6648.00(3%)
product.detail.alsoAdd.title
