製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
Note
  • If you are looking for the version with power adapter, please check out reComputer J4012 Edge device
  • For optimal performance with reComputer, we recommend using 128GB / 256GB / 512GB / 1TB SSDs from Seeed. Since some SSDs on the market may only be compatible with specific JetPack versions which may cause the device to fail to function properly, and this issue is also present with official NVIDIA dev kits.
仕様
Jetson Orin NX System on Module
AI Performance
reComputer J4012 - Orin NX 16GB, 100 TOPS
reComputer J4011- Orin NX 8GB – 70 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
CPU
8-core Arm® Cortex®-A78AE v8.2 64-bit CPU (Orin NX 16GB)
6-core Arm® Cortex®-A78AE (Orin NX 8GB)
Memory
16GB 128-bit LPDDR5 (Orin NX 16GB)
8GB 128-bit LPDDR5 (Orin NX 8GB)
DL Accelerator
2x NVDLA v2
Video Encode
1x 4K60 (H.265) | 3x 4K30 (H.265) | 6x 1080p60 (H.265) | 12x 1080p30 (H.265)
Video Decode
1x 8K30 (H.265) | 2x 4K60 (H.265) | 4x 4K30 (H.265) | 9x 1080p60 (H.265) | 18x 1080p30 (H.265)
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
I/O
USB
4x USB 3.2 Type-A (10Gbps)
1x USB2.0 Type-C (Device Mode)
Camera
2x CSI (2-lane 15pin)
Display
1x HDMI 2.1
Fan
1x 4 pin Fan Connector (5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC
1x RTC 2-pin, supports CR1220 (not included)
Power
9-19V DC
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 58.5mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃
Warranty
1 Year
ハードウェア概要
  • Desktop, wall Mount, expandable, or fit in anywhere
用途
Application Fields:
AI Video Analytics
Machine Vision
Autonomous Mobile Robot (AMR)
Generative AI
● Capable of Bringing Generative AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
● Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) reComputer J4012 can take 18x1080p30 streams. See our tested YOLOv8 performance using NVIDIA Deepstream of single model and multi model on multi streams.
● Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8, and others. We have configured all environment for you to provides single command deployment of projects.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
NVDIA Jetson Orin™ NX 16GB
x1
Seeed carrier board (reComputer J401) x1
x1
128GB NVMe SSD x 1
x1
Aluminum heatsink with fan x1
x1
Aluminum case (black) x1
x1
reComputer J4012 (w/o power adapter) - Edge AI Computer with NVIDIA® Jetson™ Orin™ NX 16GB (Super Mode NOT Supported)
SKU 110110184
Powerful and compact edge AI device with NVIDIA® Jetson Orin™ NX SoM, pre-built Jetpack 5.1.1, 128GB SSD, 4x USB 3.2, HDMI, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
[Discount on First 5 Only] From the 6th unit onward, the original price will apply.
Series
Wireless Connector
Processor
Memory
Power Adapter
GMSL
JPY¥214014.00
¥220634.00
Save ¥6620.00(3%)
