Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Compact Size Suitable for robotics and drone applications
  • 48V Compatible Can be used in 48V battery power system (max 54V input)
  • Rich IO capabilities Includes USB ,CAN, I2C,RJ45 and SPI
  • Orin compatibility Compatible with both Jetson Orin™ NX and Orin™ Nano
  • Stackable Can be stacked onto reComputer mini carrier board for usage
Extension Board
I/O
Ethernet
1x RJ45 Gigabit Ethernet (10/100/1000M)
USB
4x USB 3.0 Type-A (5Gbps)
CAN
CAN0: XT30(2+2) x 2
CAN1: JST Connector x 2
I2C
2x I2C
SPI
2x 60 pin High Speed Connector (For extension board)
1x 10 pin Power Connector (For extension board)
Mechanical
Dimensions (W x D x H)
56mm x 88mm x 34mm
Weight
75g
Installation
Desk, wall-mounting
Operating Temperature
-10℃~50℃
Warranty
1 Year
Mini Carrier+Extension
A603
Voltage
12-54V
9-20V
USB
6x USB 3.0/3.2 Type-A
2x USB 3.2 Type-A
CAN
XT-30 connector for easy and stable connection
Pin-header connection
Separate Connectors
Separate connectors for I2C/SPI/UART for easy integration
Pin-header connection. Modification of wiring needed.
Pricing
$148 combined
$170
Hardware Overview
Application
● Robotic Control
  • Capable of Bringing Generative AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
  • Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) reComputer J4012 can take 18x1080p30 streams. See our tested YOLOv8 performance using NVIDIA Deepstream of single model and multi model on multi streams.
  • Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8; and others. We have configured all environment for you to provides single command deployment of projects.
Certification
HSCODE8543909000
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
reComputer Mini Extension Boardx1
reComputer Mini Extension Board for Jetson Orin™ Nano/Orin™ NX
SKU 114993593
reComputer Mini Extension Board is designed to be connected to reComputer Mini Carrier board, and has a JST board attached to it. It provides IO extensions (Ethernet, IIC, CAN etc) that are widely used on autonomous machines such as drones, patrol robots, delivering robots, etc. It is attached to the bottom of reComputer Mini Carrier Board and needs to be used along with the reComputer Mini Carrier Board.
JPY¥9339.00
