おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
  • Brilliant AI Performance for Production: Achieves up to 40 TOPS AI performance with low power and latency, built by NVIDIA Orin SoC combining the NVIDIA Ampere™ GPU architecture with 64-bit operating capability, integrated advanced multi-function video and image processing, and NVIDIA Deep Learning Accelerators.
  • Hand-Size Edge AI Device: Compact size at 63mm x 95mm x 66.7mm, featuring an NVIDIA Jetson Orin Nano 8GB module, Mini J401 carrier board, fan and enclosure. Support desktop and wall mounting.
  • Expandable with Rich I/Os: Includes up to 8x USB, DP 1.4, 1x RJ45 for GbE, M.2 Key E, M.2 Key M, dual channel CAN, and GPIO.
  • Accelerate Solutions to Market: Pre-installed JetPack 6.0 on 128GB NVMe SSD, Linux OS BSP, supporting Jetson software and leading AI frameworks.
  • Scale to deploy: support OTA, remote management services powered by Allxon and Balena.
  • Flexible Customization: inlcudes changing accessories modules, logo, and hardware interfaces modification based on reComputer Mini J3011 original design.
仕様
Jetson Orin System on Module
AI Performance
reComputer Mini J4012 - Orin NX 16GB, 100 TOPS
reComputer Mini J3011- Orin Nano 8GB – 40 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
CPU
8-core Arm® Cortex®-A78AE v8.2 64-bit CPU (Orin NX 16GB)
6-core Arm® Cortex®-A78AE (Orin Nano 8GB)
Memory
16GB 128-bit LPDDR5 (Orin NX 16GB)
8GB 128-bit LPDDR5 (Orin NX 8GB)
Video Encode
1x 8K30 (H.265) | 2x 4K60 (H.265) | 4x 4K30 (H.265) | 9x 1080p60 (H.265) | 18x 1080p30 (H.265)
1080p30 supported by 1-2 CPU cores
Video Decode
1x 8K30 (H.265)
2x 4K60 (H.265)
4x 4K30 (H.265)
9x 1080p60 (H.265)
18x 1080p30 (H.265)
1x 4K60 (H.265)
2x 4K30 (H.265)
5x 1080p60 (H.265)
11x 1080p30 (H.265)
DL Accelerator
2x NVDLA v2
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2242 SSD 128G included)
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
I/O
USB
2x USB 3.2 Type-A (10Gbps);
1x USB 2.0 Micro-B (Device Mode);
1x USB 3.2 Type-C (Host Mode);
1x USB 2.0 JST-5pin (Host Mode);
UART
1x UART
1x Debug Uart
Display
1x DP 1.4 (included in Type-C conenctor)
Fan
1x 4 pin Fan Connector (5V PWM)
Button
1x Reset Button; 1x Recovery Button
Extension Port
2x 60 pin High Speed Connector (For extension board)
1x 10 pin Power Connector (For extension board)
RTC
1x RTC 2-pin
Power
1 x XT30 Connector (12-54V DC)
Extension Board
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
I/O
USB
4 x USB 3.0 Type-A (5 Gbps)
CAN (Providing Power)
CAN0:XT30(2+2)x2
CAN1:JSTx2
FAN
I2C
2 x I2C JST 4pin (3.3V)
SPI
1 x SPI JST 6pin (3.3V)
Mechanical
Dimensions (W x D x H)
63mm x 95mm x 42mm (Without Extension)
63mm x 95mm x 66.7mm (With Extension)
Weight
345g (Without Extension)
462g (With Extension)
Installation
Desk, Wall-mounting
Operating Temperature
-10℃~50℃
Warranty
1 Year
ハードウェア概要
● Desktop, wall Mount, expandable, or fit in anywhere
用途
● Robotic Control
  • Capable of Bringing Generative AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
  • Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) reComputer J4012 can take 18x1080p30 streams. See our tested YOLOv8 performance using NVIDIA Deepstream of single model and multi model on multi streams.
  • Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8; and others. We have configured all environment for you to provides single command deployment of projects.
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer Mini J3011 (with Extension)
x1
Antenna
x2
xt30 to DC power connector
x1
reComputer Mini J3011 with Extension - Intelligent Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 8GB
SKU 114993551
reComputer Mini J3011 is a tiny AI computer powered by NVIDIA® Jetson Orin™ Nano 8GB module,delivering up to 40 TOPS AI performance. It‘s equipped with PCIe port at the bottom to provide rich expansion capabilities, including up to 8 USB ports and dual CAN, which also can be customized flexibly. The whole system is designed for embedding into autonomous machines such as drones, patrol robots, delivering robots, etc. It can directly occupy 54V DC input, able to be widely used in battery powered systems.
Processor
Memory
Extension Board
USD$709.00
product.detail.alsoAdd.title
