おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Ruggedized Hardware Design: Ruggedized edge AI computer with IP66 rating that can be deployed in harsh environment
  • Lockable and Waterproof connectors: M12 for all interfaces (Ethernet (PSE), DI, DO, RS‑232/422/485, and CAN), plus lockable/waterproof USB connectors.
  • Application and Benefit: Ideal for rapid development of autonomous vehicles in harsh environments(AGV, AMR,trucks), accelerating time-to-market with ready-to-use interfaces and optimized AI frameworks.
  • Ready to Use: Pre-installed with JetPack 5.1.3 and equipped with WiFi6 module.
  • Wide Operating Range: Operates reliably across a temperature range of -20°C to 60°C at 15W mode
仕様
Module Specifications
ProductreComputer Rugged J3011
ModuleNVIDIA Jetson Orin™ Nano 8GB
AI PerformanceOrin Nano 8GB – 40 TOPS
GPU1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
GPU Max Frequency625 MHz
CPU6-core Arm® Cortex®-A78AE
CPU Max Frequency1.5 GHz
Memory8GB 128-bit wide LPDDR5 DRAM (up to 68GB/s)
Power7W - 15W
Video Encode1080p30 supported by 1-2 CPU cores
Video Decode1x 4K60 (H.265)
2x 4K30 (H.265)
5x 1080p60 (H.265)
11x 1080p30 (H.265)
Mechanical69.6mm x 45mm
260-pin SO-DIMM connector
Box Specifications
Storage1x M.2 KEY M PCIe (128G SSD included)
NetworkingM.2 KEY E1x M.2 Key E for WiFi/Bluetooth module (WiFi Module Included)
M.2 KEY B1x M.2 Key B for 5G module
SIM1x Nano-SIM slot
Ethernet5x RJ-45 Gigabit Ethernet (4x PSE, all M12)
I/OUSB4x USB 3.0 Type-A (5Gbps)
1x USB 3.0 Type-C (Recovery)
1x USB 2.0 Type-C (Debug)
CAN2x CAN (M12)
Display1x HDMI
DI/DO2x DI, 2x DO (M12)
Serial1x RS-232/422/485 (M12)
RTC1x RTC 2-pin
1x RTC Socket (CR1220 Battery Included)
LED2x LED (PWR, SSD)
Button1x Recovery
1x RESET
Antenna Hole4x Antenna Hole
Power19-48V M12 A-code connector
Jetpack VersionJetpack 5.1.3
MechanicalDimensions (W x D x H)210mm*190mm*95mm
(Bottom Panel is 250mm * 210mm)
Weight3.5kg
InstallationDesk, Wall-mounting
Operating Temperature-20℃~60℃ (15W Mode)
Warranty2 Years
Certification
(Pending)
RoHS, CE, FCC
ハードウェア概要
用途
Outdoor video analytics
For outdoor video analytics and monitoring, equipment must operate reliably outdoors despite constant exposure to UV radiation, moisture, temperature fluctuations, and mechanical vibration. With its IP66-rating enclosure, reComputer Rugged can be used in outdoor environments for such purposes. Paired with computing power of NVIDIA Jetson Orin modules, reComputer Rugged J30 is a powerful edge AI gateway for remote monitoring stations.
Autonomous Logistics
Outdoor AMRs are increasingly deployed in urban and facility management environments to perform autonomous security patrols and last-mile delivery services. These multi-purpose robots are designed to navigate seamlessly through both indoor and outdoor environments. Therefore they need reComputer Rugged with NVIDIA® Jetson Orin™ as brain of AI-powered navigation systems that combine LiDAR, ultrasonic sensors, cameras, and GPS to map complex environments and avoid pedestrians, vehicles, and obstacles in real-time.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
Jetson Orin™ Nano 8GB modulex 1
Seeed Carrier Board (reComputer Rugged J401)x 1
128GB NVMe SSDx 1
Aluminum Case and Heatsinkx 1
Waterproof USB Cable; Type A to Type Ax 1
M12 A-code Power Cablex 1
M12 A-code 8-pin Cablex 1
M12 X-code to RJ45 Cablex 1
Terminal Block femalex 1
Terminal Block malex 1
DC Power cablex 1
USB Type-C to Type-A Cablex 1
User Manualx 1
reComputer Rugged J3011 - Ruggedized IP66 Edge AI Computer with NVIDIA® Jetson Orin™ Nano 8GB
SKU 100002634
reComputer Rugged J3011 is a ruggedized edge box powered by NVIDIA® Jetson Orin™ Nano 8GB with IP66 rating. It is equipped with M12 and sealed connectors, providing IOs such as USB, Ethernet (including PSE), CAN, RS-232/422/485 and DI/DO. It has M.2 Key B slot for 5G modules, making it ideal to be used in ruggedized applications, such as AMR, robotics, agriculture, industrial and maritime applications. It can be directly used in 48V systems and has interfaces for most common sensors.
[Discount on First 5 Only] From the 6th unit onward, the original price will apply.
reComputer Rugged J4012
USD$1260.03
$1299.00
Save $38.97(3%)
product.detail.alsoAdd.title
