製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
  • Super Boost AI Performance: Delivers up to 67 TOPS in MAXN Super Mode, ideal for demanding applications like vision AI, robotics, and generative AI.
  • Energy-Efficient Operation: Configurable power modes from 10W to 25W allow for optimized performance and energy consumption.
  • Robust Thermal Design: Operates reliably in temperatures from -20°C to 65°C.
  • Rich interfaces: Features 2x RJ45, SIM card, 4x USB 3.2, HDMI 2.1 and CAN. Also including M.2 Key E/M, Mini-PCIe, 4x Mipi-CSI for connectivity and cameras.
  • Ready for Deployment: Pre-installed with JetPack 6.2 (Supports JP7.2) and a 128GB NVMe SSD, supporting AI frameworks like NVIDIA Isaac, Hugging Face, and ROS2/1, enabling rapid development of various AI applications.
Jetson Orin Nano / Orin NX Modules Performance with Super Mode
  • Memory Bandwidth Upgrade
  • Higher Throughput
  • Improved higher frame rate processing
  • Enhanced Power Management
  • Reduced Inference Latency
Built for developers, the reComputer Super J3011 is an enhanced upgrade over the reComputer J3011. It takes edge AI development further with key enhancements: dual GbE (RJ45) ports, LTE, 4x Mipi-CSI for Camera, and full support for MAXN Mode.
仕様
reComputer Super J3010
Applications Processor(AP)
NVIDIA Orin™ Nano 4GB
NVIDIA Orin™ Nano 8GB
AI Performance
Orin Nano 4GB – 34 TOPS(MAXN_SUPER)
Orin Nano 8GB – 67 TOPS(MAXN_SUPER)
GPU
512-core NVIDIA Ampere architecture GPU with 16 Tensor Cores
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
GPU Max Frequency
1020 MHz (MAXN_SUPER)
CPU
6-core Arm® Cortex®-A78AE
CPU Max Frequency
1.7 GHz (MAXN_SUPER)
Memory
4GB 64-bit wide LPDDR5 DRAM(up to 34GB/s; 51 GB/s MAXN_SUPER)
8GB 128-bit wide LPDDR5 DRAM(up to 68GB/s; 102 GB/s MAXN_SUPER)
Power
7W - 10W - 25W
7W - 15W - 25W
Video Encode
1080p30 supported by 1-2 CPU cores
Video Decode
1x 4K60 (H.265)
2x 4K30 (H.265)
5x 1080p60 (H.265)
11x 1080p30 (H.265)
CSI camera
Up to 4 cameras
(8 via virtual channels***)
8 lanes MIPI CSI-2
D-PHY 2.1 (up to 20Gbps)
Mechanical
69.6mm x 45mm
260-pin SO-DIMM connector
Carrier Board
Storage
1x M.2 KEY M PCIe (M.2 NVMe 2280 SSD 128G included)
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
Mini PCIe
1x mini-PCIe for LTE 4G module
Ethernet
2x RJ45 Gigabit Ethernet
I/O
USB
4x USB 3.2 Type-A (5Gbps);
1x USB 2.0 Type-C (Device Mode/Debug);
Camera
4x mipi CSI(2-lane 15-Pin)
CAN
1 x CAN(4-Pin Header)
Display
1x HDMI 2.1
Fan
1x 4-Pin 1.25mm Fan Connector (5V PWM)
1x 4-Pin 2.54mm Fan Connector (12V PWM)
Extension Port
1x 40-Pin extension header
1x 12-Pin control and UART header
RTC
1x RTC 2-pin
1x RTC Socket
LED
2x LED(PWR and ACT)
Button
1x PWR
1x RESET
Switch
1x REC
Antenna hole
4x Antenna Hole
Power
12-19V 5525 Barrel DC Jack
Jetpack Version
Jetpack 6.2
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 66mm
Weight
1110g
Installation
Desk, Wall-mounting
Operating Temperature
-20℃~65℃
Warranty
2 Years
Certification
RoHS,REACH,CE,FCC,UKCA, KC
ハードウェア概要
用途
Designed for Developers — Out-of-the-Box Experience:
Whether you're an experienced developer or a complete beginner for embedded AI/GPU inference, use reComputer Super AI box as your first AI workstation, together diving into NVIDIA Jetson for Beginners — your fast track to vision AI, Generative AI, and robotics development! Through these tutorials, you will learn:
  • From Zero to Real Projects: Master Linux basics on the Jetson environment to build an end-to-end AI NVR/AMR.
  • Hardware Integration: Tailored for reComputer Jetson devices for a seamless, out-of-the-box experience.
  • Coverage of Cutting-Edge Domains: Deep dive into CV, GenAI, ROS, agentic AI, and TensorRT optimization.
  • Toolchain Mastery: Hands-on tutorials with NVIDIA JetPack SDK, CUDA, DeepStream, PyTorch, and TensorFlow.
To improve the developer experience, Seeed offers reComputer AI Lab — a platform that helps you deploy AI applications with one-click tools and ready-to-use resources. It includes optimized edge AI model demos for CV, LLM, VLM, interactive tutorials, deployment tools, containerized applications, and community projects to speed up development on Jetson.
Seeed Jetson Develop Tool is a desktop client for all developers who are going to use reComputer Jetson device for the very first time. It brings the common bring-up and development workflow into one GUI: firmware flashing, first-boot initialization, device diagnostics, remote development, app deployment, skill-based automation, OTA updates, and community resources. All we provide here is to help you to get started with Seeed reComputer Jetson hardware much more easily and seamlessly.
Ready to build a solution for the real world? We have Jetson-example prepared for you! It offers one-line deployable projects compatible with generative AI large models, including LeRobot, Ollama, Qwen, etc; with computer vision such as Ultraslytics YOLO26. We have configured all environment setups for you to provide a single command deployment of projects, easy to try out/verify if the trending model performance is suitable for your GPU needs and application scenarios.
Designed for Multi-Camera Vision AI:
Powered by the reComputer Super AI box, the system supports up to 4x USB cameras or MIPI-CSI cameras  to create a 360° panoramic vision network. Leveraging the advanced spatial foundation model, it processes multiple real-time video streams simultaneously to deliver accurate depth perception, comprehensive environmental awareness, and real-time blind-spot elimination for safer autonomous operation.
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
Jetson Orin™ Nano 8GB module
x 1
Seeed Carrier Board (reComputer Super J401)
x 1
128GB NVMe SSD
x 1
Aluminum Case and Heatsink with Fan
x 1
USB Cable; Type A to Type C
x 1
User Manual
x 1
reComputer Super J3011 - Advanced Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 8GB in Super Mode
SKU 114110312
The reComputer Super J3011 is an open-source, high-performance Edge AI computer powered by the Jetson™ Orin™ Nano 8GB platform. Delivering up to 67 TOPS in Super MAXN mode (supporting JP7.2), it is engineered to drive advanced AI models and frameworks. Built for rapid development and production, the system features a wide operating temperature range (-20°C to 65°C), robust wireless connectivity (Wi-Fi, Bluetooth, LTE), and dual Gigabit Ethernet ports.
Series
Processor
Memory
GMSL
JPY¥121713.00
