おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
仕様
Jetson Orin NX 16GB System on Module
AI Performance
reServer Industrial J4012 - Orin NX 16GB, 100 TOPS
reServer Industrial J4011- Orin NX 8GB – 70 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
CPU
8-core Arm® Cortex®-A78AE v8.2 64-bit CPU (Orin NX 16GB)
6-core Arm® Cortex®-A78AE (Orin NX 8GB)
Memory
16GB 128-bit LPDDR5 (Orin NX 16GB)
8GB 128-bit LPDDR5 (Orin NX 8GB)
Video Encode
1x 4K60 (H.265) | 3x 4K30 (H.265) | 6x 1080p60 (H.265) | 12x 1080p30 (H.265)
Video Decode
1x 8K30 (H.265) | 2x 4K60 (H.265) | 4x 4K30 (H.265) | 9x 1080p60 (H.265) | 18x 1080p30 (H.265)
DL Accelerator
2x NVDLA v2
1x NVDLA v2
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
I/O
Ethernet
1x RJ45 GbE (10/100/1000M)
4x RJ45 GbE PoE(PSE 802.3 af 15 W, 10/100/1000Mbps)
USB
4x USB3.1 Type A, 2x USB2.0 Type C
DI/DO
4x DI, 4x DO, 3x GND_DI, 2x GND_DO, 1x GND_ISO, 1x CAN
Display
1x HDMI 1.4
Fan
1x 4 pin Fan Connector (5V PWM)
COM
1x DB9 (RS232/RS422/RS485)
SATA
2x Drive Bays to support 2.5" SATA HDD/SSD(SATA III 6.0Gbps)
SIM
1x Nano SIM card slot
Button
Reset Button, Recovery Button
Expansion
RTC
1x RTC 2-pin, supports CR1220 but not included
Mini PCIe
1x Mini PCIe for LoRaWAN®/4G/Series Wireless (Module optional)
M.2 Key B
1x M.2 Key B (3042/3052) support 4G/5G (Module optional)
Fan
Fanless, passive heatsink; 1x Fan connectors(5V PWM)
TPM
1x TPM 2.0 connector (Module optional)
Power
DC 12V-36V Terminal block 2 pin
Mechanical
Dimensions (W x D x H)
194.33mm x 187mm x 95.5mm
Installation
Desk, DIN rail, VESA
Weight
2.8kg
Operating Temperature
-20 ~ 60°C with 0.7m/s
Operating Humidity
95% @ 40 °C (Non-condensing)
Storage temperature
-40 ~ 85°C
Storage humidity
60°C@ 95% RH(Non-condensing)
Vibration
3 Grms @ 5 ~ 500 Hz, random, 1 hr/axis
Shock
50G peak acceleration (11 msec. duration,eMMC,microSD,or mSATA)
Warranty
2 Years
ハードウェア概要
Full System
Carrier Board
用途
  •  Unlock AI capabilities for existing cameras and VMS
Powered by the NVIDIA Jetson Orin NX 16GB processor, delivering up to 100 TOPS of AI performance, and capable of processing multiple video streams in real-time. The reServer empowers you to apply high-performance filters for critical insights across vast video footage.
  •  Smart Storage Solutions
Store and upload only noteworthy recordings for further processing. With two 2.5-inch hard drive bays, the reServer Industrial provides ample storage capacity, ensuring you have the space needed for expanding data requirements.
  • Create custom analytics made it easy
  • Out-of-box tailor AI solution
CVEDIA-RTcomes with various AI models for face detection, vehicle and people detection, crowd estimation, and more.
  •  Build video analytics workflow in a no-code way.
Effortlessly create custom video analytics solutions using Lumeo's innovative drag and drop tools.
  • End to end Computer Vision Development
Our wiki help you start with the computer vision software and development tools during each step of your application.
  • obtain data for training
  • label data for dataset preparation
  • train AI models
  • optimize models to run the best on the edge device
  • deploy the model on the edge
  • remote management
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reServer Industrial J4012 (System Installed)
x 1
DIN rail bracket
x 1
Bracket screw
x 10
16-Pin Terminal block for DIO
x1
24V/5A Power adapter (without power cord)
x 1
2-Pin Terminal block power connector
x 1
Note:
Please note that the product comes with a power adapter, but does not include a AC cloverleaf power cord. Kindly purchase the appropriate AC cloverleaf power cord based on your local power socket specifications.
reServer Industrial J4012- Fanless AI-enabled NVR Server with NVIDIA Jetson Orin™ NX 16GB module
SKU 114110247
reServer J4012 brings AI-enabled NVR to the edge and features NVIDIA Jetson Orin™ NX 16GB for 100 TOPS AI performance, has a fanless design, 5xRJ45 GbE with PoE, 2x Drive bays for 2.5" HDD/SSD, 1xRS232/RS422/RS485, 4xDI/DO, 1xCAN, Pre-installed JetPack System.
Processor
Memory
USD$1899.00
product.detail.alsoAdd.title
