おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Rugged design for harsh working environment: IP65 front panel, -10~50°C operating temperature
  • Open-source design in software and hardware: Powered by Raspberry Pi CM4, easy for customization or derivatives with the PCIe extensions design, integrated a camera and a PoE module
  • Cost-effective Device Master: HMI, PLC, Panel PC and gateway all-in-one. Perfect for the distributed hub devices
  • Low code programming for event-driven applications: Natively integrated Node-RED for flow-based editing and one-click deployment, compatible with all software runs on Raspberry Pi
  • Hybrid connectivity: Support 4G LTE, LoRaWAN®, Wi-Fi, BLE, RS485/RS232, CAN bus, 1000M Ethernet, USB, HDMI
  • Product Warranty: Two-year warranty
Note: Product Lifetime:at least until 2034 (Based on Raspberry Pi)
仕様
Basic
CPU
CM4 Quad-core Cortex-A72@ 1.5GHz
Memory
8GB
Storage
32GB eMMC
M.2 NVMe SSD Slot 2280-M Key (optional)
*This optional feature requires the additional purchase of an 512GB NVMe M.2 PCle Gen3x4 2280 Internal SSD - Seeed Studio and a Dual LAN & SSD PCIe Extension Board (SKU 114993112)
OS Support
Raspbian
SenseCraft Edge OS
Display
Size
10.1''
Max. Resolution
1280 x 800
Max. Colors
16.7M (8-bit)
Luminance (nit)
400
Viewing Angle (H/V°)
170/170
Backlight Life (hrs)
30000
Touch Type
10-point Capacitive
Pencil Hardness
7H
Video&Audio
Video
HDMI2.0
Audio
2 x Microphone
Buzzer
3.5mm Audio Jack
Camera
Connector: CSI
Chip type: Sony IMX219
Resolution for image: 3280x2464
Resolution for video: 1080p30, 720p60 and 640x480p90
Size: 25mm x 23mm x 9mm
Interfaces
Ethernet
1 x 10/100/1000 Mbps
2 x 10/100/1000 Mbps (optional)
*This optional feature requires the additional purchase of a Dual LAN & SSD PCIe Extension Board (SKU 114993112)
USB
2 x USB-A 2.0 Host
RS485
1 x RS485 > Terminal Block
1 xRS485 > DB9 (optional)
*This optional feature requires the additional purchase of a Dual DB9 PCIe Extension Board (SKU 114993111)
RS232
1 x RS-232 > Terminal Block
1 xRS-232 > DB9 (optional)
CAN
1 x CAN-BUS > Terminal Block
DI
4x DI > Terminal Block
DO
4x DO > Terminal Block
40pin GPIO
Inside
Wireless Communication
Wi-Fi
On-chip Wi-Fi
*This optional feature requires the additional purchase of a Raspberry Pi Compute Module 4 Antenna Kit - Seeed Studio
BLE
On-chip BLE
LoRa®
Mini-PCIe for LoRaWAN® (optional)
*This optional feature requires the additional purchase of a LoRa Antenna Kit for reTerminal DM - 868-915 MHz - Seeed Studio and a region-optional LoRaWAN Gateway Module (SPI) (SKU 114992967), WM1302 LoRaWAN Gateway Module (SPI) - EU868, based on SX1302 - Seeed Studio)
Cellular
Mini-PCIe for 4G (optional)
*This optional feature requires the additional purchase of a 4G Antenna Kit for reTerminal DM - Seeed Studioand LTECat4EC25-AFXGA-mini-PCIe - 2G/3G/4G communication, built-in multiple GNSS - Seeed Studio, LTECat4EC25-AFXGA-mini-PCIe - 2G/3G/4G communication, built-in multiple GNSS - Seeed Studio)
Power
Input
2-pin Terminal Block
PoE
12.95W PoE
Power Range
12~24V DC
*There is no adapter in the standard product. Please purchase the correct
PowerAdapter, 12V/2A/24W, American Standard Plug, DC Output - Seeed Studio,
PowerAdapter, 12V/2A/24W, European Standard Plug, DC Output - Seeed Studio
version separately if required.
Power Consumption
6W Typ.
9W Max.
Power Switch
NO
Reboot Switch
YES
Environment
Ingress Protection
IP65 Front Panel
Operating Temperature
-10~50 °C
Storage Temperature
-20~70 °C
Humidity (Operating)
10~95% RH
Mechanical
Dimension (W x H x D)
259.4 x 191 x 42.2 mm
Enclosure
Die-cast Aluminum Alloy
Mounting
Panel, VESA, DIN-rail
*There is no mounting accessories in the standard product. If PanelmountKitforreTerminalDM-Seeed Studio or Sliding Block for Linear Guideway Rail(screws included) - Seeed Studio accessories are required, please purchase them separately.
Weight (Net)
1.8Kg
Vibration Resistance
5 Grms random vibration (5 ~ 500Hz) during operation, IEC60068-2-64
Shock Resistance
Operating 50 G peak( 11ms duration), IEC 60068-2-27
Certification
CE, FCC, UCKA, RoHS, TELEC, REACH
EMC
ESD
EN61000-4-2, Level 3
EFT
EN61000-4-4, Level 2
Surge
EN61000-4-5, Level 2
Others
RTC
High Accuracy RTC (with a CR2032 battery)
Hardware WatchDog
1~255s
Security
ATECC608A
Warranty
2 Years
Heat Dissipation
Fanless
ハードウェア概要
reTerminal DM is an integrated device master that can function as an HMI/PLC/Gateway/Panel PC all-in-one device, working in the edge layer of the IOT architecture, unifying data flow, and managing onsite devices, reducing the big gap between legacy systems and modern IT infrastructures in various application scenarios.
用途
The reTerminal DM HMI presents a versatile solution applicable across numerous industries. Seamlessly integrating cutting-edge technologies, it streamlines operations and enhances efficiency. Running on the Home Assistant platform and employing Computing Vision, Cloud solutions, and platforms like N3uron, Ignition Edge, and Node-RED, along with our proprietary platform, Sensecraft Edge OS, it opens up exciting possibilities for developers and enthusiasts alike.
  • Energy Management: Monitor grids, monitor and maintain solar panels.
  • Building Management: Central control panel for BAS, individual room control panels.
  • MedTech: Medical device control panel, patient monitoring station.
  • Construction: BIM, Monitor sites, control heavy machinery.
  • Transportation: Monitor vehicle health, control ticketing systems (buses, trains).
  • Agriculture:  Control irrigation systems, monitor greenhouse conditions.
  • Retail:  Display digital signage, control self-checkout kiosks.
  • Logistics: Track inventory movement, manage warehouse operations.
  • Water Management: Monitor water treatment plants, control water distribution.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reTerminal DM (Camera & PoE)
x 1
20-pin Terminal Block Connector(Male)
x 1
2-pin Power Female Jack to Screw Terminal Adapter
x 1
Screw Pack
x 1
Fuse
x 1
User Guide
x 1
Wi-Fi/BLE feeder cable(installed)
x 1
Wi-Fi/BLE Antenna
x 1
reTerminal DM - 10.1'' HMI| CM4108032 | Raspberry Pi Rugged Panel PC | Panel Controller | with Camera & PoE
SKU 114070221
reTerminal DM is a Panel PC, HMI, IIoT Gateway all-in-one device powered by Raspberry Pi CM4, with 10.1'' IP65 front panel and supports Raspberry Pi-based software ecosystem.It is equipped with rich interfaces, supporting CAN bus, RS485, RS232, Gigabit Ethernet, as well as powerful wireless communication capabilities such as 4G, LoRa®, Wi-Fi, and BLE.
Model
Display Size
RAM
eMMC
JPY¥95582.00
廃番
product.detail.alsoAdd.title
Customize Design recomputer
