About Seeed Studio XIAO
Seeed Studio XIAO Series is a collection of thumb-sized, powerful microcontroller units (MCUs) tailor-made for space-conscious projects requiring high performance and wireless connectivity. Embodying the essence of popular hardware platforms, the Arduino-compatible XIAO series is the perfect toolset for you to embrace tiny machine learning (TinyML) on the Edge.
Join the XIAO NewsletterThumb Sized
mm
Trusted by
Developers
Popular SoCs Integrated
ESP32, RP2040/2350, nRF52/54, SAMD21, MG24, RA4M1, STM32 and more for embedded machine learning on MCUs.
Thumb Size With SMD
Sized at 21×17.8 mm with a single-sided surface-mount design, ready for space-constrained and tap-on designs.
TinyML Native
Compatible with Seeed’s no-code model training and deployment platform SenseCraft AI, making TinyML scalable.
Developer-Friendly
Natively compatible with Arduino, supporting PlatformIO, MicroPython, and CircuitPython.
XIAO in a Glimpse
From core development boards to expansion add-ons and ready-to-use smart gadgets — one ecosystem, endless possibilities
You Decide What We Build Next
We’re open-sourcing our roadmap for XIAO on GitHub, and you have a say in it. Vote for your favorite entries, suggest features, propose new products, or share feedback.
Developers, join us and shape the next XIAO!
Join NowHardware Partners
Software Partners
Projects Built on XIAO
Projects from GitHub, Youtube, Instructables, Hackster, Hackaday, and more, all well-curated on XIAO Project Hub.
Building an AI Smart Speaker with the reSpeaker XVF3800
A voice-first smart-home system built around the reSpeaker XVF3800 with XIAO ESP32-S3: on board runs the Xiaozhi assistant "Joy" (wake word "Hi, Joy"), which turns natural-language requests into real appliance actions and smart-home scenes. A second XIAO ESP32-S3 powering a Home Controller drives a Grove 4-channel relay for switching and reads a Grove SHT40 temperature/humidity sensor, while a CrowPanel Advance 7 touchscreen dashboard shows device states and live readings for touch control.
_QSUE9ZDANv.gif?auto=format%2Ccompress&gifq=35&w=1600&h=1200&fit=min&fm=jpg)
IMU Electronic Ocean
A desk-sized rhythmic nightlight built on XIAO STM32C5: the on-board 6-axis IMU is read and fused, then mapped onto two 6x10 WS2812 matrices to recreate bioluminescent “blue tears” waves, colour flows that follow gravity, plus low-power wake-up from IMU motion or a Grove Button.
How to read codes from (many) IR remote controls with as little code as possible
A from-scratch minimal NEC infrared decoder for XIAO boards: an IR demodulator wired to a header pin or the QWIIC socket captures 32-bit remote codes, and the firmware converts them into USB HID key presses (volume, mute, play/pause, skip) so any IR remote can drive media playback on a PC or Mac.
MyroNode: Real-Time IMU-to-Servo Teleoperation with ROS-2
A robotic teleoperation system using two XIAO STM32C5 boards to map IMU orientation to serial bus servo motion over CAN FD, with ROS 2 integration and RViz2 visualization.
no_DICE
A XIAO RP2040-based device for rolling dice, flipping coins and keeping score, featuring an OLED display, a rotary encoder and a 3D-printed enclosure.
Handsy — AI agent that operates a real iPhone with a XIAO ESP32-S3
The XIAO ESP32-S3 plugs into an iPhone as its USB mouse and keyboard and receives the phone's AirPlay Screen Mirroring. The computer talks to the XIAO over Bluetooth, so an AI agent such as Claude Code or Codex can see and tap the phone through the esp32agent CLI and MCP server. No jailbreak required. Open source under the MIT license; docs at https://handsy.tech/docs/cli
Metal Gear Solid running natively on the ESP32-S3
This project brings Metal Gear Solid, originally released for the PlayStation 1, to the XIAO ESP32-S3 Sense. The game runs directly on the ESP32-S3 with an LCD display, using the microcontroller as the actual gaming platform rather than emulating a PlayStation 1. The project explores how far the ESP32-S3 can be pushed by porting a real 3D PlayStation-era game to a tiny microcontroller. I also used Velxio, my browser-based embedded development and simulation platform, to iterate and test the firmware before flashing it to the physical XIAO ESP32-S3 Sense. The source code and technical details are available in the project article.
SMARS ROVER
SMARS ROVER is a modular robotic rover with a finger gripper, controlled remotely over a video stream and powered by an ESP32.
TRMNL 7.5-inch DIY Weather Dashboard
An ESPHome and Home Assistant weather dashboard for the Seeed Studio TRMNL 7.5-inch DIY Kit. It presents current conditions, daily forecasts, precipitation timing, air quality, allergen levels, and local sensor data, with 15-minute or button-triggered updates optimized for battery operation.
Genius GM6000 BLE Mouse Revival
An open-source restoration of the classic Genius GM-6000 mechanical ball mouse. A custom PCB built around the Seeed Studio XIAO nRF52840 Sense preserves the original ball and encoder mechanics while adding Bluetooth LE and wired USB HID, automatic air-mouse mode, a rechargeable battery, and multi-stage power management.
TrailNAV: Solar-Powered Off-Grid Exploration Device
A solar-powered offline navigation device built for outdoor exploration, waypoint tracking, and off-grid adventures. Built with the Seeed Studio XIAO ESP32-C6, a 2.7" Waveshare ePaper display, NEO-M8N GPS module, QMC5883L digital compass, and CN3791 MPPT solar charging module. Features sunlight-readable display, physical button interface, ultra-low-power operation, and a DIY PVC sunboard enclosure.
AirBird (Indoor Air Quality Monitor): the Bird That Could Save Your Life
An IoT indoor air quality monitor housed inside a 3D-printed bird. When CO₂ levels spike or TVOC climbs into dangerous territory, a stepper motor silently rotates the bird upside down — turning invisible air chemistry into a visceral visual warning. Built with the Seeed Studio XIAO ESP32-C6 and SparkFun CCS811/BME280 combo sensor (eCO₂, TVOC, temp, humidity, pressure over I²C). Powered by Li-Ion battery with onboard charging. Open-source Arduino sketch with 3D-printable STL files, no cloud dependency.
The RoadBook — Rally-Inspired GPS Device for Riders & Adventurers
A rally-inspired digital road book GPS device built with the Seeed Studio XIAO ESP32-S3 (via EE05 ePaper Display Board) and a 4.26" monochrome ePaper display. Instead of turn-by-turn navigation, it works like rally co-drivers think — pre-planned waypoints count down distance as you ride, auto-advancing at 50m. Features real-time GPS tracking via L76K GNSS (GPS/BeiDou/GLONASS/QZSS), an emergency info button (displays blood type & contacts), and a Wi-Fi configuration page for trip management. 3D-printed enclosure, battery-powered.
The Best Air Sensor is One You Can Make Yourself
A comprehensive tutorial on building the ultimate smart home air quality sensor using the Seeed Studio XIAO ESP32-C6 and Sensirion SEN66 sensor. Covers the full build from basic sensor readings to advanced features — ePaper/eInk display integration, ESPHome configuration (no programming required), Home Assistant dashboard with beautiful UI, and custom 3D-printed enclosure. Open-source design files on GitHub and 3D models on Printables/Makerworld.
Build A Stealth MeshCore Repeater: Harbor Freight Hack!
A portable stealth MeshCore mesh network repeater built using the Seeed Studio XIAO nRF52840 with Wio SX1262 LoRa kit, hidden inside a Harbor Freight solar motion sensor light. Runs MeshCore firmware for off-grid mesh communication. A creative ham radio / IoT project combining off-the-shelf hardware with open-source mesh networking firmware for portable field deployment.
MINTIA Micropython Console
A DIY handheld game console built into a MINTIA breath mint candy box using the Seeed Studio XIAO RP2350 and a 1.54" 240×240 ST7789 IPS display. Runs MicroPython with AI-generated code for Tetris and other games. Features 8 tactile buttons (D-pad + A/B + Start/Select), LiPo battery power with onboard charging, and a 3D-printed back panel. Open-source sample code on GitHub.
XIAO ESP32-S3 Sense Retro Camera
A compact retro-styled digital camera built on the Seeed Studio XIAO ESP32-S3 Sense. Captures 1280×720 photos and MJPEG/PCM audio video with a 2.0" TFT live viewfinder. Features encoder-driven menu, on-device gallery with thumbnail previews, self-timer, timelapse, slideshow, and a tabbed WiFi file server with QR code pairing. Built on FreeRTOS multi-core architecture.
ESP Dash — Local ESP32 Sensor Data Visualization
A tutorial demonstrating ESP Dash for locally visualizing ESP32 sensor data via web dashboard. Built with the Seeed Studio XIAO ESP32-C5 and XIAO Logger HAT featuring temperature, humidity, light sensor, RTC, and battery voltage monitoring. Uses PlatformIO and ESPAsyncWebServer to create a real-time dashboard running entirely on the local network without cloud dependency.
Tripwire — Cyberpunk ESP32 BLE & WiFi Radar Scanner
A wireless reconnaissance platform built around the XIAO ESP32-C5 that detects, visualizes, and logs Bluetooth and WiFi activity in real time. Features a round TFT radar display, SD card logging, geiger-style proximity audio, and rechargeable battery. Tracks devices via RSSI with a cyberpunk-inspired radar UI for portable situational awareness.
Sneaky Gestures V2 — Bluetooth Gestural MIDI Glove
A wearable BLE-MIDI gestural instrument glove built on the Seeed XIAO nRF52840 Sense. Features 12 conductive finger pads for scale-quantized note playing, flex sensor for glissando pitch bend, thumb FSR for aftertouch, and dual-axis accelerometer for continuous MIDI CC control. Includes 20 selectable scales, tap tempo, 63 presets, RGBW LED display, and serial patch backup. Transmits as standard BLE-MIDI to any DAW or hardware synth.
Mood Paint
A bio-responsive painting system that turns physiological signals into real-time generative visuals. A wearable glove or bracelet uses XIAO ESP32-C3 with heart-rate and galvanic-skin-response sensors, translating the captured data into changing colors, movement, density, and rhythm.
Bit:busy — LED Bar That Indicates Your Work Status
An LED status bar that indicates whether you are busy or free, so colleagues won't distract you. Built with the Seeed Studio XIAO ESP32-C3 and WS2812B 8x32 LED Matrix. Features a local web server at bitbusy.local with three modes: Manual (BUSY/FREE toggle), Pomodoro Timer (25-min focus, 5-min break), and Custom message. Runs entirely on local Wi-Fi with no cloud dependency. Open-source firmware on GitHub.
Make your own satellite
A fully functional CanSat (miniature satellite designed to fit inside a soft drink can) built with the XIAO ESP32-C6. Measures real-time atmospheric data (temperature, pressure, humidity, orientation) and transmits telemetry via LoRa (RYLR998) to a ground station. Features a parachute deployment system for controlled landing. Perfect for students in robotics, electronics, and aerospace engineering.
Build Battery Powered Smart Home Devices (Xiao nRF52840 + Matter)
A comprehensive tutorial on building ultra-low-power Matter smart home devices using the Seeed Studio XIAO nRF52840 and nRF Connect SDK. Covers SDK setup, power optimization, bootloader (MCUBoot), OTA updates, CHIP factory data, Device Tree, ZAP + Matter Data Model, and full code walkthrough with an SHT41 sensor. Open-source code on GitHub.
This Tiny Device Detects WiFi & Bluetooth Attacks in Real Time
A compact XIAO-based Bluetooth & WiFi attack detector for ethical hacking enthusiasts. Built around the XIAO ESP32-C5, this device detects and displays network information using radio frequency detection. Features a custom software interface, mobile app integration, 6×10 RGB Matrix display, and open-source GitHub code with 3D-printable case.
$40 Wireless Vibe Coding Voice Keyboard
A step-by-step guide to building a wireless vibe coding voice keyboard for under $40 using Seeed Studio XIAO nRF52840 Sense. Features Bluetooth voice-to-text input for hands-free coding, with a Grove OLED display for feedback and Grove Mech Keycap. Designed for accessibility and creative coding workflows.
ET MeetingRoom ePaper Sign — SharePoint Room Reservation Display
An integrated ePaper meeting room sign built around the Seeed Studio XIAO ESP32-S3 that bridges a reTerminal E1002 full-color ePaper display with a SharePoint Server 2019 room-booking calendar. The XIAO acts as a lightweight REST API wrapper, caching SharePoint OData results and serving clean JSON to a SenseCraft HMI-powered display. Designed for on-premises deployment with no cloud dependency and military-grade security.
DIY JOY AI Desktop Companion Robot
An AI desktop companion robot built with the Seeed Studio ReSpeaker XVF3800 4-Mic Array with XIAO ESP32S3 for voice detection and AI processing. Features an OLED display for facial expressions, speaker with amplifier for voice responses, and a custom 3D-printed body. Uses Xiaozhi open-source voice AI firmware for wake word detection and natural conversation.
Gratitude Loom
A ritual weaving instrument that combines hand weaving, sensing, and cloud intelligence. Hall effect sensors read the rhythm and consistency of each weaving action, then the system selects or generates the next pattern while the weaver remains free to change, pause, or end the process.
Corporate Slave Digital Phone DP192 — Reviving a 1996 Phone with ESP32
A creative revival of a 1996 Good Design Award-winning digital mobile phone (Nippondenso DP192) using Seeed Studio XIAO ESP32-C3. The phone checks a designated email inbox every 5 minutes and alerts via OLED display and buzzer when matching keywords are found. Part of the 'Corporate Slave Warning Light' series for system fault monitoring, with open source Arduino code available on GitHub.
Modular Wearable Platform — Stackable Electronics with XIAO nRF52840
A modular wearable development platform built around the Seeed Studio XIAO nRF52840, where each function lives on its own stackable module. Features heart rate monitoring via MAX30101, step counting via MPU6050 IMU, OLED display output, and Bluetooth BLE data transmission. An early prototype demonstrating a flexible approach to wearable system design.
Sleeper Matter Sensor — Ultra-Low-Power XIAO nRF52840 Smart Home Sensor
An ultra-low-power Matter smart home sensor built around the Seeed Studio XIAO nRF52840, engineered for years of battery life. Features Matter protocol integration for local-only Home Assistant control, SHT41 temperature and humidity sensing, and LiPo fuel gauge. Demonstrates intermittent connectivity strategies for Matter devices with cross-platform power analysis.
NIMO — ESP32 Desk Buddy Robot with Motion Sensing & Emotions
A DIY ESP32 desk buddy robot with animated OLED eyes and MPU6050 motion sensing. Built around the XIAO ESP32-C3, features shake-to-emotion reactions (Dizzy → Angry), live weather mood with 3-day forecast, RTC, world clock, and touch navigation. Fully 3D-printed enclosure with open-source code and STL files.
DIY AI Pin — Wearable Vision/Voice Assistant
A compact wearable AI device built with the XIAO ESP32-S3 Sense that clips onto your chest and can see, hear, and respond to voice commands. Features camera-based vision for object recognition, voice AI for natural conversation, and IoT device control. Open source project with downloadable firmware and schematic on GitHub.
How to make 3D Printed Spy Car at home | Spy Camera Car | ESP32 CAM | DIY Robot
I built a fully 3D printed WiFi FPV Spy Car using XIAO ESP32 S3. Build your own spy car with live video streaming.
ESP32 Matter Tutorial #4 | Build Your Own Matter Sensor! XIAO ESP32-C6 + Home Assistant
Build a Matter-compatible sensor using XIAO ESP32-C6 with Home Assistant integration.
DIY ESPHome Controller | Build a Custom Smart Home Device (with a Seeed Xiao ESP32-C3)
Build a custom smart home device using Seeed Xiao ESP32-C3 with ESPHome integration.
How I made a free Internet Radio with ESP32
Build a standalone internet radio receiver using the XIAO ESP32S3 with ST7735 TFT display.
I Built the Smallest Real-Time GPS Tracker using XIAO ESP32C3!
Build a compact GPS tracker with SOS and real-time tracking using XIAO ESP32-C3 and SIM800C.
Open source ESP32 AI Chatbot - DIY
DIY AI assistant using XIAO ESP32-S3 with I2S audio modules for voice interaction.
I Built an AI Desk Assistant That Can Rewrite it's Own Code!
AI desk assistant that can rewrite its own code, built with XIAO ESP32-S3 Sense featuring touch display.
Make Your Own Fallout Smart Watch
DIY Fallout-style smart watch powered by XIAO ESP32-S3 with custom retro post-apocalyptic UI.
DIY Zigbee Temperature Sensor with XIAO ESP32C6
Build your own Zigbee temperature sensor with XIAO ESP32C6 using PlatformIO and Home Assistant.
Meshtastic with XIAO nRF52840
Mesh networking solution using XIAO nRF52840 with Meshtastic firmware for long-range off-grid communication.
pico-cec
HDMI CEC to USB HID keyboard adapter. Supports XIAO RP2350 and Raspberry Pi Pico boards.
Smart Matter Button using XIAO ESP32 C6
Tutorial on building a smart Matter button using Seeed XIAO ESP32 C6 with Arduino.
VFD Display with XIAO ESP32S3 NTP Clock
Build a VFD display clock with animations using Seeed XIAO ESP32S3 and NTP time sync.
Solar Powered Water Tank Level Sensor V2
Build a solar powered wireless water tank level sensor using Xiao ESP32C3 with BLE.
no_DICE
SMARS ROVER
Mood Paint
Gratitude Loom
pico-cec
XIAO Playground
Pick a board. Explore. Build. Play.
Co-Create with XIAO
Design and scale up your custom XIAO-based projects from scratch with Seeed Fusion Co-Create Services of prototyping, production and promotion. Get FREE prototyping sponsorship for your XIAO-based PCBA design fabrication. We'll also list outstanding designs for sale on the Seeed webstore, and designers will receive a license fee for each piece sold.
Learn More→
Scale-up Co-Create Projects
Find out how the community is scaling up their XIAO-based projects via our Fusion Co-Create.
XIAO in the News
Discover the latest news on XIAO, updates from Seeed and from our community all over the world
