おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Introducing our high-performance antenna with exceptional frequency range and gain. Our antenna is designed to provide superior connectivity for your devices, offering a frequency range of 824-960/1710-2700 MHz. It has an output impedance of 50 Ω and a gain of 2 dBi, which allows for optimized signal strength.
This antenna has a vertical polarization and omnidirectional radiation pattern, ensuring a stable signal reception from all directions. With a maximum input power of 5 W, it can handle high-power transmissions with ease.
Designed to withstand harsh environments, this antenna has an operating temperature range of -40℃ to +70℃ and a storage temperature range of -45℃ to +75℃. This makes it an ideal choice for various applications, including industrial, commercial, and residential.
Whether you're looking to enhance the connectivity of your devices or improve the performance of your wireless system, our high-performance antenna is the perfect solution for you.
  • Really to connect: Provide IPEX connector and SMA connector to connect with a 4G module
  • Up to 2 dBi Peak Gain
  • -30~+80 ℃ operating temperature
仕様
Parameter
Frequency range (MHz)
824–960 / 1710–2700
VSWR (Max)
3.0:1
Peak Gain, dBi (Typ)
Up to 2.0
Nominal Impedance
50 Ω
Max Power (ambient temp of 25°C)
10 Watts
Azimuth Beam Width (deg)
Omnidirectional
Polarization
Linear, Omnidirectional
Radome
PC, Black
Storage Temperature Range (°C)
-40° C to +85° C
Operational Temperature Range (°C)
-30° C to +80° C
ハードウェア概要
How to connect with reTerminal DM
用途
  • Wireless sensor networks
  • Industrial automation
  • IoT devices
  • Smart cities
  • Wireless communication networks
ドキュメント
認証
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8531202090
COOCHINA
部品リスト
4G Antenna Kit
x1
SMA connector
x1
IPEX connector
x1
4G Antenna Kit for LTE Cat 4 EC25 mini-PCIe
SKU 110061502
This is a 4G Antenna with 2 dBi Gain and -30~+80 ℃ operating temperature.
USD$5.00
product.detail.alsoAdd.title
