おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Multiple navigation system applications supported:
    • BD: BeiDou Navigation System
    • GPS: Global Positioning System
    • GLONASS: GLONASS Navigation System
  • Enhanced Frequency Range:
    • BD: 1561±2MHz
    • GPS: 1575.42MHz±2MHz
    • GLONASS: 1602MHz±5MHz
仕様
lectrical characteristics
Parameter
Value
Antenna model
3540A
Dimensions
35mm x 35mm x 4mm
Frequency Range
BD: 1561±2MHz
V.S.W.R
2.0 MAX
Bandwidth@10dB
BD: 5MHz
GPS: 5MHz MIN
GLONASS: 10MHz MIN
Passive Gain
BD: 5.0 dB typ @ 70x70mm ground plane
GPS: 5.0 dB typ @ 70x70mm ground plane
GLONASS: 5.0 dB typ @ 70x70mm ground plane
Active Gain
BD: 22±3dB typ @ 2000mm RG174 line
GPS: 23±3dB typ @ 2000mm RG174 line
GLONASS: 22±3dB typ @ 2000mm RG174 line
LNA Gain
GPS: 22±3dB typ @ 2000mm RG174 line
Impedance
50Ω
Polarization
RHCP
DC Voltage
3.3±0.3V
DC Current
12±2mA(@3.0V)
Material
Part Name
SPEC
Antenna
Dielectric Ceramics
Shielding
Tinplate
PCB
FR4
Sheathing
ABS (black)
Dimensions: 50.8mm×50.8mm×16.5mm
RF Cable
RG174
Length: 2000mm
RF Connector
SMA MALE
Magnet
Nd2FeB magnet
Working Temperature
-40℃~+85℃
Relative Humidity
10%~95% RH
Storage Temperature
-55℃~+100℃
Vibration
Sine sweep @1.5mmAM 10~55Hz each Axis
ハードウェア概要
How to connect with reTerminal DM
As you can see below: this antenna should be installed on the 4G module on the reTerminal DM.
用途
  • Wireless communication systems in industrial automation
  • Wireless data transmission for smart agriculture
  • Connection for remote monitoring and control systems
  • Wireless networking for smart homes and buildings
  • Wireless monitoring in environmental monitoring systems
  • Wireless connectivity for IoT devices in various industries.
認証
HSCODE8529109090
USHSCODE8517710000
UPC
EUHSCODE8531202090
COOCHINA
部品リスト
GPS Antenna Kit
x1
GPS Antenna Kit
SKU 110061521
The GPS Antenna Kit is a compact and high-performance antenna designed for GPS, BD, and GLONASS Navigation System applications. With its small dimensionsand excellent frequency range, it provides reliable signal reception and transmission all devices.
USD$7.00
product.detail.alsoAdd.title
