Note
Specifications | Jetson AGX Orin 32GB H01 Kit | NVIDIA® Jetson AGX Orin™ Developer Kit: smallest and most powerful AI edge computer - Seeed Studio |
AI Performance |
200 TOPS |
275 TOPS |
GPU | 1792-core NVIDIA Ampere GPU with 56 Tensor Cores | NVIDIA Ampere architecture with 2048 NVIDIA® CUDA® cores and 64 Tensor Cores |
CPU | 8-core NVIDIA Arm® Cortex A78AE v8.2 64-bit CPU 2MB L2 + 4MB L3 | 12-core Arm® Cortex®-A78AE v8.2 64-bit CPU 3MB L2 + 6MB L3 |
Memory | 32 GB 256-bit LPDDR5 204.8 GB/s | |
DL Accelerator | 2 x NVDLA v2.0 | |
Vision Accelerator | 1 x PVA v2.0 | |
Storage | 64GB eMMC 5.1 | |
Video Encoder | 1x 4K60 | 3x 4K30 | 6x 1080p60 | 12x 1080p30 (H.265) 1x 4K60 | 2x 4K30 | 5x 1080p60 | 11x 1080p30 (H.264) | 2x 4K60 | 4x 4K30 | 8x 1080p60 | 16x 1080p30 (H.265) |
Video Decoder | 1x 8K30 | 2x 4K60 | 4x 4K30 | 9x 1080p60| 18x 1080p30 (H.265) 1x 4K60 | 2x 4K30 | 5x 1080p60 | 11x 1080p30 (H.264) | 1x 8K30 | 3x 4K60 | 6x 4K30 | 12x 1080p60| 24x 1080p30 (H.265) |
Display | 1* HDMI 2.1 | 1* DisplayPort 1.4a (+MST) |
Camera | 1* 16 lane MIPI CSI-2 connector | |
Networking | 1* GbE 1* 10GbE | 1* 10GbE |
USB | 2x USB 3.2 Type-A (Integrated USB 2.0), 1x USB 3.2 Type-C (Integrated USB 2.0) | 2x USB 3.2 Gen2 Type-Cwith USB-PD support 4x USB 3.2 Gen2 Type-A USB 2.0 Micro-B
M.2 Key M | 1* M.2 Key M | |
M.2 Key E | 1* M.2 Key E (pre-installed WIFI+BT:BL-M8822CP1 | / |
Fan | 1* 4-pin fan (5V PWM) | 1* 4-pin fan |
microSD card slot | 1 * microSD card slot | |
Audio Jack | 1* 3.5mm audio jack | / |
RTC | 2-pin RTC | |
RS485 | 1* RS485(3P 1.5mm pitch) | / |
RS232 | 1* RS232(3P 1.5mm pitch) | / |
Others | 40-pin header, 1* SPI Bus(+3.3V Level), 6* GPIO(+3.3V Level), 1x CAN, Force Recovery, Reset and Power ON/ OFF buttons, 12V/2A 2-pin power output | 40-pin header, 12-pin automation header, 10-pin audio panel header, 10-pin JTAG header, Force Recovery, and Reset buttons |
Power Supply | 9~20V DC Input @ 8A | 19V via USB Type-C |
Mechanical | 107mm x 106.4mm x 70.5mm | 110mm x 110mm x 71.65mm |
Operating Temperature | -25 ⁰C to +70 ⁰C | 0 ⁰C to 35 ⁰C |
DC Jack connector(Please disregard the silkscreen on the housing, and use following table as power polarity reference):
Plug Center | Positive (+) |
Outer Shell | Negative (-) |
Top View
Bottom View
Product Change Log:
Jetson AGX Orin 32GB H01 Kit is ideal for building autonomous applications and complex AI tasks of image recognition, object detection, pose estimation, semantic segmentation, video processing, and many more. The following are few of the applications that have been tested with Xavier NX and you can take them for reference in order to build applications using AGX Orin as well.
Find in the Jetson Community Resources page tools and tutorials the community has created to power your development experience, and check out the Community Projectspage to inspire your next project!
Jetson AGX Orin 32GB | ×1 |
Seeed carrier board | ×1 |
Aluminum heatsink with fan | ×1 |
Aluminum case | ×1 |
19V/4.74A(Barrel Jack 5.5/2.5mm) power adapter | ×1 |
Wi-Fi/BT module(BL-M8822CP1) | x1 |
AGX Orin 32GB H01 has been discontinued. For replacement, please see reComputer Mini J5011 and reComputer Classic J5011 with AGX Orin 32GB.
Jetson AGX Orin 32GB H01 Kit is built with Jetson AGX Orin 32GB Module, offering 200 TOPs AI performance. Provide rich interfaces including PCIe X16, GbE, 10GbE, 3* USB 3.2, HDMI 2.1, M.2 Key M, M.2 Key E, 16 lane MIPI CSI-2, 40Pin header. The kit is pre-installed with JetPack 5.1.2.
