Jetson AGX Xavier H01 Kit is built with Jetson AGX Xavier Module, offering 32 TOPs AI performance as well as a carrier board including PCIe X16, Gigabit Ethernet, 2x USB 3.0, USB 2.0, HDMI, M.2 Key M, and M.2 Key E, 2.4/5GHz Wi-Fi, Bluetooth, (16x) CSI-2 Lanes, UART, 40-Pin header, The kit is pre-installed with JetPack System, cooling fan and aluminum case. The next generation Jetson AGX Orin Dev kit is also avalible at Seeed, brings 8 times AI performance and the same form factor as the Jetson AGX Xavier Dev kit.
Jetson AGX Xavier H01 is ideal for robots, drones and other autonomous machines. With this compact AI computer, you can easily create and deploy end-to-end AI autonomous applications for manufacturing, delivery, retail, agriculture, and more.
Supported by NVIDIA JetPack and DeepStream SDKs, as well as CUDA®, cuDNN, and TensorRT software libraries, the kit provides all the tools you need to get started right away.
The on-demand delivery company Postmates that operates across the United States presented a new all-electric autonomous delivery robot equipped with the latest NVIDIA Jetson AGX Xavier module for autonomous machines at GTC Silicon Valley in San Jose.(source: NVIDIA)
Last-mile delivery: Cainiao Et Lab adopts Jetson AGX Xavier to accelerate the development of autonomous logistic Vehicles(ALVs). It’s equipped with several sensors such as lidars, cameras, GPS, and inertial measurement units (IMUs). (source: NVIDIA)
Meituan provides an innovative and holistic solution for autonomous delivery, which incorporates an online order platform, dispatch system, and road network logistics with big data optimization. (source: NVIDIA)
Malamute, our Edge AI partner, has integrated NVIDIA Embedded AGX Xavier, NVIDIA RIVA, and Snap Inc. Ghost’s AR Innovation Lab at their Atlas Communication System, an on-equipment industrial messaging system using natural language processing and spatial computing to improve workplace productivity and process traceability. Read the blog here.
DEVELOPER KIT I/OS | Jetson AGX Xavier Developer Kit | Jetson AGX Xavier H01 Kit |
| Developer Kit I/Os | Jetson AGX Xavier Module Interface | Jetson AGX Xavier Module Interface |
| PCIe X16 | x8 PCIe Gen4/x8 SLVS-EC | x8 PCIe Gen4/x8 SLVS-EC |
| RJ45 | Gigabit Ethernet | Gigabit Ethernet |
| USB-C | 2x USB 3.1, DP (Optional), PD (Optional) Close-System Debug and Flashing Support on 1 Port | 20PIN 0.5mm ZIF FPC(achieve USB-C 3.0 with corresponding convert ports) |
| Camera Connector | (16x) CSI-2 Lanes | (16x) CSI-2 Lanes |
| M.2 Key M | NVMe | NVMe |
| M.2 Key E | PCIe x1 + USB 2.0 + UART (for Wi-Fi/LTE) / I2S / PCM | PCIe+UART+I2S/PCM (pre-installed Wi-Fi+BT:8265.NGWMG.NV 949399) |
| 40-Pin Header | UART + SPI + CAN + I2C + I2S + DMIC + GPIOs | UART + SPI + CAN + I2C + I2S + DMIC + GPIOs |
| HD Audio Header | High-Definition Audio | - |
| eSATAp + USB3.0 Type A | SATA Through PCIe x1 Bridge (PD + Data for 2.5-inch SATA) + USB 3.0 | USB3.0 Type A*2 |
| HDMI Type A | HDMI 2.0 | HDMI 2.0 |
| uSD/UFS Card Socket | SD/UFS | TF Card Socket |
At Seeed, you will find everything you want to work with NVIDIA Jetson Platform – official NVIDIA Jetson Dev Kits, Seeed-designed carrier boards, and edge devices, as well as accessories.
Seeed will continue working on the Jetson product line and will be ready to combine our partners’ unique technology with Seeed’s hardware expertise for an end-to-end solution.
Seeed’s Edge AI platform provides devices, carrier boards, peripherals, software tools, and ML solutions. Seeed is NVIDIA’s official reseller and ecosystem hardware partner. By consolidating our best-in-class hardware and and cutting-edge technology from our software partners and the community, we aim at helping both developers and enterprises deploy ML in the real world across industries. Contact us at [email protected]
We are looking forward to working with AI experts, software enterprises, and system integrators:
Note
| Jetson Xavier AGX H01 Kit | x1 |
| 19V/4.74A Power Adapter | x1 |
| ZYJB (antenna) | x2 |
The Jetson AGX Xavier H01 Development Kit is powered by NVIDIA Jetson AGX Xavier processor which applies AI performance and delivers up to 32 Tera Operations Per Second(TOPs) yet costs less than 30W. It is an ideal solution to agriculture, optical inspection, manufacturing, robotics, logistics, retail, service, smart cities, and healthcare.
Check out more NVIDIA Jetson-powered edge devices comparison!
