おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Arduino Nano ESP32 is a compact board with a powerful ESP32S3 microcontroller running up to 240 MHz. It offers 2.4 GHz Wi-Fi and Bluetooth, and comes with a wide range of peripherals. This board supports MicroPython and Arduino and includes a MicroPython 101 course for easy programming guidance.
Feature
  • Tiny footprint ESP32 MCU Board by Arduino: Build upon the ESP32S3 microcontroller while operating up to 240 MHz, yet designed with a compact size
  • Wireless Capability: Equip the 4 GHz Wi-Fi and Bluetooth® wireless connection, compatible with Arduino IoT Cloud
  • A wide range of peripherals: Offer 14x digital I/O pins, 8x analog input pins, and 5x PWM pins, and provide 2x UART, 1x IIC, 1x SPI data communication
  • Multiple Development Approaches: Support MicroPython and Arduino programming
  • MicroPython 101 course attached
The Arduino Nano ESP32 is the first Arduino board based on an ESP32 microcontroller from Espressif, the NORA-W106 module from u-blox®. USB-C® connector, 16 MB (128 Mbit) of Flash, support for MicroPython & Arduino IoT Cloud enabled, it is a very versatile development board.
The Arduino Nano ESP32 features the NORA-W106, a module with an ESP32-S3 chip inside. This module supports both Wi-Fi® and Bluetooth® (5.0 and above), making it an ideal device for IoT development. The popular Nano form factor also makes it compatible with many hardware accessories.
This combination of features allows for a wide range of applications and makes it an excellent choice for IoT development projects.
Application
  • Internet of Things (IoT) Projects
  • Remote Monitoring and Control
  • Wireless Sensor Networks (WSN)
  • Data Loggers
  • Robotics and Automation
Specifications
Item
Details
Microcontroller
u-blox® NORA-W106 (ESP32-S3)
USB connector
USB-C®
Pins
Built-in LED Pin
13
Built-in RGB LED pins
14-16
Digital I/O Pins
14
Analog input pins
8
PWM pins
5
External interrupts
All digital pins
Connectivity
Wi-Fi®
Bluetooth®
Communication
UART
2x
I2C
1x, A4 (SDA), A5 (SCL)
SPI
D11 (COPI), D12 (CIPO), D13 (SCK). Use any GPIO for Chip Select (CS)
Power
I/O Voltage
3.3 V
Input voltage (nominal)
6-21 V
Source Current per I/O Pin
40 mA
Sink Current per I/O Pin
28 mA
Clock speed
Processor
up to 240 MHz
Memory
ROM
384 kB
SRAM
512 kB
External Flash
128 Mbit (16 MB)
Dimensions
Width
18 mm
Length
45 mm
Hardware Overview
Part List
Arduino Nano ESP32 without headersx1
15pinHeaderx2
  • Is the Nano ESP32 compatible with MicroPython?
Absolutely! This board fully supports MicroPython. For detailed information on setting it up and getting started with MicroPython, please visit docs. arduino. cc/nano-esp32.
  • How can I power the Nano ESP32?
The Nano ESP32 can be powered in two ways. Firstly, you can power it via the USB port, which activates the VBUS pin as an output. Alternatively, you can supply power through the VIN pin, accepting an input voltage range of 5 to 18 Volts.
  • Does it use the official ESP32 core?
Yes, if you are an ESP32 user, simply install the latest version of the Arduino Nano ESP32 core through the board manager in the Arduino IDE. For more information, please refer to the official documentation page.
  • Will the Nano ESP32 be compatible with sketches from generic ESP32 boards?
The Arduino Nano ESP32 can run code written for other ESP32 devices without any fuss. It's designed to be fully compatible with the ESP32 ecosystem, making it easy to port existing code.
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOItaly
Arduino Nano ESP32 - ESP32S3, Wi-Fi, Bluetooth, 14x digital I/O, 8x analog input, 5x PWM, 2x UART, 1x IIC, 1x SPI, support MicroPython and Arduino
SKU 102991794
USD$20.00
廃番
product.detail.alsoAdd.title
