Check out our new arrivals!
reComputer Jetson-10-1-H0 built with Jetson Nano Production Module, reComputer Jetson-20 built with Jetson Xavier NX Production Module also includes on-device carrier board and heatsink.
This is a world-leading ToF module with high precision, VGA high resolution, compact and easy to use.
The IMX556 is a fully integrated optical Time-of-Flight (ToF) camera sensor. The sensor features 640 x 480 (VGA) time-of-flight pixels based on the DepthSense® pixel technology. Combined with a modulated light source, this sensor is capable of measuring distance and reflectivity with VGA resolution.
Model | DepthEye Turbo |
Sensor/Pixel Size | Sony IMX556PLR CMOS /10 μm |
Resolution/FPS | 0.3MP 640 x 480 px/ Max 30 FPS |
Dimension &Weight | 50 x 50 x 50 mm / 258 g |
Accuracy | Less than 5mm (0.7m to 1.5m) |
Precision | Standard deviation less than 2mm at 1m |
Near Mode: up to 1.5m | |
Working Range | Far Mode: up to 6m |
FOV | H31.2° x V23.8° |
Data Interface | USB 3.1 Gen1 /Type C |
Power Consumption | Near Mode : 5V / 1A (Peak) /0.6A(Average) |
Far Mode : 12V / 1A (Peak) /0.5A(Average) | |
Illumination | 4 x VCSEL laser diodes @ 850nm |
Operating Temperature | -10° C to 60° C case temperature |
Platform support | Windows/Linux/Mac/Ros |
SDK language support | C++/Python |
1 x DepthEye Turbo
1 x Type-C cable
1 x 12V Power Cable
heatsink.
